need browser restart, freezing stream WORKAROUND
athorretto
Post by athorretto » Tue Feb 23, 2010 11:59 pm
Hi all
i'm a new user of zm, now running on a vm(vmware server 2) ubuntu server 9.04 zm 1.24.1.
After a couple days i fixed up configuration for my needs, but firefox freeze after, sometimes 1 minute, sometimes 10 secs; the solution is to erase cache(restart firefox sometimes) or reload apache as we well know.
Regarding this issue i read a lot in the forum but worksrounds i found didn't solve my problem, anyway helps understanding components involved in this issue.
One thing that can't understand: why the fps value is going negative in the moment of the freeze? someone else notice that?
searching in the /var/www/zm for "fpsValue" with grep (the relative id on the php page) this is the result:
skins/classic/views/js/watch.js
skins/classic/views/js/montage.js
skins/classic/views/watch.php
skins/classic/views/montage.php
focusing on "skins/classic/views/watch.php" ,simply i cut off the <span> tag that display fps:
from
<div><SLANG>:&nbsp;<span></span>&nbsp;-&nbsp;<span></span>&nbsp;fps</div>
to
<div><SLANG>:&nbsp;<span></span>&nbsp;-&nbsp;&nbsp;fps</div>
this solve my problems of freezing streams that i was experiencing without restarting the browser because it didn't freeze.
Can anyone that is experiencing the same problem , try to modify the file and verify if it works properly?
Unfortunatly cutting off the span tag remove the funcion of "disable alarms" and "forced alarm" from the page, i didn't understanding yet , i think i've to look in the css.
if someone can try i hope we can find, with the help of someone that know php, an easy way to workaround this problem.
<edit>
before the mod freezing usually in 1/3 mins, now running from 1h but didn't understanding why :twisted: :twisted: help !
<edit>
jfkastner
Post by jfkastner » Wed Feb 24, 2010 2:45 am
for whatever reason the ONLY FF version that works for me with ALL menus/windows/controls reliably was 3.0.7
you can use 307 just for ZM and don't care about the security/update issues, and have another FF for the web access
athorretto
Post by athorretto » Wed Feb 24, 2010 1:07 pm
edit:
no freeze in 12h, can anyone try this workaround ?????????
this could help to find a good solution
danisam
Post by danisam » Fri Jun 04, 2010 6:47 pm
i will try,give me the day.
regards
Pictux
Post by Pictux » Sun Jun 06, 2010 11:42 am
I solve the freeze problem refreshing browser.
Here my solution:
http://www.zoneminder.com/forums/viewto ... 2502#62502
Regards
M
danisam
Post by danisam » Sun Jun 06, 2010 9:32 pm
I just perform the change in watch.php and it's seems that my freeze pb is fixed.
But when i went to the multi view , i can see the FPS an the page freeze.
Where can i find this php page to chenge the same.
BEst regards
danisam
Post by danisam » Sun Jun 06, 2010 9:44 pm
after hours of tests i can say that my freeze problem in Apache is gone.
Thank you very much athorretto.
Now i need to search the Clycle and mutiple camera PHP pages.
best regards all
Long life to Zoneminder.
danisam
Post by danisam » Sun Jun 06, 2010 10:34 pm
I found it in :
/var/www/skins/classic/views/montage.php
i will continue my tests but i think you find the problem.
Users browsing this forum: No registered users and 5 guests
