JMK-UP-010 IP cam w/ptz working
CoYoTe
Post by CoYoTe »
Product Name JMK-UP-010
Brief Name UP-010
Product Serial Number 00168E1955aa
Hardware Version 1.0.0.0
Firmware Version 1.1.0.12
Service Provider Link
http://www.jmk.com.cn
This is a basic dome IP cam, with a limited PTZ control. It only can PAN/TILT, and controls bright and contrast.
Can work at 160x120, 320x240 or 640x480.
The webserver is very simple.
It works fine with Zoneminder 1.24.2
Detailed implementation:
Remote Protocol : HTTP
Remote Method: SIMPLE
Remote Server Name: [CAM-IP ADDRESS]
Remote Server Port: 80
Remote Server Link: /cgi/sf.cgi
Remote Image Colours: 24 bits
Captura Ancho (pixels): 320
Captura Alto (pixels):240
Anonymous access must be enabled via webserver to get image.
to get PTZ working, a script is needed (based on axis control script)
In my box (Debian Squeeze + Zoneminder 1.24.2), the perl control scripts are located at
/usr/local/share/perl/5.10.1/ZoneMinder/Control
Here, you need to create a file called jmkup10.pm
and paste this into it
# ZoneMinder JMK API Control Protocol Module, $Date: 2009-11-10 06
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA  02111-1307, USA.
# This module contains the implementation of the JMK camera control
# protocol
package ZoneMinder::Control::jmkup10;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# jmkup10 Control Protocol
use Time::HiRes qw( usleep );
sub new
    my $class = shift;
    my $id = shift;
    bless( $self, $class );
    srand( time() );
    return $self;
our $AUTOLOAD;
sub AUTOLOAD
    my $self = shift;
    my $name = $AUTOLOAD;
    $name =~ s/.*://;
    if ( exists($self->{$name}) )
        return( $self->{$name} );
sub open
    my $self = shift;
    $self->loadMonitor();
    use LWP::UserAgent;
    $self->{state} = 'open';
sub close
    my $self = shift;
    $self->{state} = 'closed';
sub printMsg
    my $self = shift;
    my $msg = shift;
    my $msg_len = length($msg);
sub sendCmd
    my $self = shift;
    my $cmd = shift;
    my $result = undef;
    printMsg( $cmd, "Tx" );
    #print( "http://$address/$cmd\n" );
    if ( $res->is_success )
        $result = !undef;
    else
        Error( "Error check fallo: '".$res->status_line()."'" );
    return( $result );
sub moveConUp
    my $self = shift;
    Debug( "Move Up" );
    my $cmd = "/cgi-bin/action?action=cam_mv&diretion=cam_up&lang=eng";
    $self->sendCmd( $cmd );
sub moveConDown
    my $self = shift;
    Debug( "Move Down" );
    my $cmd = "/cgi-bin/action?action=cam_mv&diretion=cam_down&lang=eng";
sub moveConLeft
    my $self = shift;
    Debug( "Move Left" );
    my $cmd = "/cgi-bin/action?action=cam_mv&diretion=cam_left&lang=eng";
sub moveConRight
    my $self = shift;
    Debug( "Move Right" );
    my $cmd = "/cgi-bin/action?action=cam_mv&diretion=cam_right&lang=eng";
sub presetHome
    my $self = shift;
    Debug( "Home Preset" );
    my $cmd = "/cgi-bin/action?action=cam_mv&diretion=cam_home&lang=eng";
In CONTROL tab of the cam settings (remember under general OPTION to enable OPT_CONTROL so ZoneMinder can control PTZ cameras) the settings must be:
Controllable: Mark
Control Type: Must be EDITED finally name it jmkup10
Control Device: left it blank
Control Address: admin:123456@ip-of-the-cam
Auto Stop Timeout: 10.00
Track Motion: enabled
Track Delay: 1
Return Location: Home
Return Delay: 1
Edit controls, and ADD a new one called jmlup10
the items i dont mention must be left at default value (blank or 0)
on MAIN tab
Type: Remote
Protocol: jmkup10
on MOVE tab
Can Move : mark
Can Move Continuous: mark
on PAN tab
Can Pan: mark
on TILT tab
Can Tilt : mark
on PRESETS tab
Has Presets: mark
Num Presets: 0
Has Home Preset: mark
And that's it, now you can control cam via CONTROL link in single cam view or in multiple using the same link.
Alejandro
