Hi, i have a Axis 207W my config:
/axis-cgi/jpg/image.cgi?resolution=640x480
I am getting ~8 fps the max was 10 fps.
How i can to increase the fps?
It seems like ZM is not capturing all the frames that Axis 207w is sending.
Axis 207W Slow Capture, max ~8 fps
resolution=1280x1024
when i use
/axis-cgi/jpg/image.cgi?resolution=1280x1024
I get caputure 2.86 fps not more
207MW
you are right it is 207MW but I use it via cable UTP.
Still with SLOW caputure.
solved with another path
Hi, I found out the the thing. Now I am using ZM 1.24.2 and another path for the axis camera.
/axis-cgi/mjpg/video.cgi?resolution=640x480
using "mjpg" and video.cgi
Now i am capturing ~ 15 fps
hurraaa .
