Foscam Ip Camera PTZ Control
ronluna
Post by ronluna » Sat Apr 18, 2009 8:14 am
I'm looking for the PTZ commands for the "Foscam FI8908 / FI8908W Ip Camera" is anybody around here have been able to gain PTZ control over this camera please share that info...
I'm currently able to see the image feed but no luck on the PTZ... any help would greatly appreciated...
ronluna
Foscam.pm
Post by ronluna » Wed May 13, 2009 3:16 am
I was able to get some codes for Foscam IP FI8908W and based on the other pm's that zoneminder comes with this is the result
I'm not a perl guru but at least I got it to pan/tilt and center with Zoneminder 1.24.1
package ZoneMinder::Control::Foscam;
use 5.006;
use strict;
use warnings;
require ZoneMinder::Base;
require ZoneMinder::Control;
# Foscam IP Control Protocol
use Time::HiRes qw( usleep );
sub new
my $class = shift;
my $id = shift;
bless( $self, $class );
srand( time() );
return $self;
our $AUTOLOAD;
sub AUTOLOAD
my $self = shift;
my $name = $AUTOLOAD;
$name =~ s/.*://;
if ( exists($self->{$name}) )
return( $self->{$name} );
our $stop_command;
sub open
my $self = shift;
$self->loadMonitor();
use LWP::UserAgent;
$self->{state} = 'open';
sub close
my $self = shift;
$self->{state} = 'closed';
sub printMsg
my $self = shift;
my $msg = shift;
my $msg_len = length($msg);
sub sendCmd
my $self = shift;
my $cmd = shift;
my $result = undef;
printMsg( $cmd, "Tx" );
if ( $res->is_success )
$result = !undef;
else
return( $result );
sub reset
my $self = shift;
Debug( "Camera Reset" );
my $cmd = "reboot.cgi?user=admin&pwd=";
$self->sendCmd( $cmd );
sub moveConUp
my $self = shift;
$stop_command = "1";
Debug( "Move Up" );
my $cmd = "decoder_control.cgi?command=0&user=admin&pwd=";
sub moveConDown
my $self = shift;
$stop_command = "3";
Debug( "Move Down" );
my $cmd = "decoder_control.cgi?command=2&user=admin&pwd=";
sub moveConLeft
my $self = shift;
$stop_command = "5";
Debug( "Move Left" );
my $cmd = "decoder_control.cgi?command=4&user=admin&pwd=";
sub moveConRight
my $self = shift;
$stop_command = "7";
Debug( "Move Right" );
my $cmd = "decoder_control.cgi?command=6&user=admin&pwd=";
sub moveStop
my $self = shift;
Debug( "Move Stop" );
my $cmd = "decoder_control.cgi?user=admin&pwd=&command=$stop_command";
sub whiteConIn
my $self = shift;
my $params = shift;
my $step = $self->getParam( $params, 'step' );
Debug( "White In $step" );
my $cmd = "/camera_control.cgi?2=$step";
sub whiteConOut
my $self = shift;
my $params = shift;
Debug( "White Out $step" );
my $cmd = "/camera_control.cgi?2=-$step";
sub presetClear
my $self = shift;
my $params = shift;
Debug( "Clear Preset $preset" );
my $cmd = "nphPresetNameCheck?Data=$preset";
sub presetSet
my $self = shift;
my $params = shift;
my $cmd = "nphPresetNameCheck?PresetName=$preset&Data=$preset";
sub presetGoto
my $self = shift;
my $params = shift;
my $cmd = "nphControlCamera?Direction=Preset&PresetOperation=Move&Data=$preset";
sub presetHome
my $self = shift;
Debug( "Home Preset" );
my $cmd = "decoder_control.cgi?command=25&user=admin&pwd=";
1;
if someone want to help finishing this script for full control.... this are the commands:
snapshot.cgi
description To obtain the snapshot
Permission visitor
Syntax /snapshot.cgi[?user=&pwd=&next_url=]
Parameters user:username
pwd:password
next_url:the name of snapshot
Note 1 If not use the parameter “next_urlâ€
e_lm_70
Post by e_lm_70 » Tue Aug 18, 2009 9:10 pm
Thanks ronluna,
Here is the "full" list of code after upgrade the FW: 2.4.8.11
var PTZ_STOP = 1;
var TILT_UP = 0;
var TILT_DOWN = 2;
var PAN_LEFT = 4;
var PAN_RIGHT = 6;
var PTZ_LEFT_UP = 90;
var PTZ_RIGHT_UP = 91;
var PTZ_LEFT_DOWN = 92;
var PTZ_RIGHT_DOWN = 93;
var PTZ_CENTER = 25;
var PTZ_VPATROL = 26;
var PTZ_VPATROL_STOP = 27;
var PTZ_HPATROL = 28;
var PTZ_HPATROL_STOP = 29;
var IO_ON = 94;
var IO_OFF = 95;
So, actually, stop is always 1 ... maybe there is back compatibility with previous stops code.
What is new is move up&left, down&right, etc
A easy way to make some easy reverse enginering, is just have a look of the new FW for the GUI :wink:
Tchuss
e_lm_70
ps: In my opinion the security of this and all the IP-WEB cam are too poor ... I made with TomCat a HTTP wrap up of my home cam ... based on Ubuntu over Acer One ... now I'm sure nobody can spy my home.
user name and password in clear form, not in HTTPS, is trivial to break in .. just a sniffer and you lost your privacy ...
Users browsing this forum: No registered users and 11 guests
