apache and firefox
fc
apache and firefox
Post by fc »
Hi there
using am 1.24 on arch linux installed from ZMarch livecd .
Most times when using firefox to see saved events i loose connection to the server, normally what i would do is a restart to the httpd and all come to life again..
Today i noticed that when firefox freeze i tried with Internet explorer and my apache is responding to internet explorer but not to firefox.......
Strange , any clue ?
the issue is that when i use Iexplorer i receive an error that i can't read "combozola something" when trying to see the streams.
so i'm stuck :
firefox "crashes" Apache and
iexplorer don't work with combozola
any advice would be welcomed
kingofkya
Post by kingofkya »
you need to install it into the zm root read the readme for more info
fc
Post by fc »
update...
when i try to use iexplorer/cambozola or change the Z_Stream_method to mpeg i got this on messases file :
Mar 4 01:05:49 zmhost httpd: socket_sendto( /var/lib/zm/socks/zms-035093s.sock ) failed: No such file or directory
Mar 4 01:05:49 zmhost httpd: array (
Mar 4 01:05:49 zmhost 0 =>
Mar 4 01:05:49 zmhost array (
Mar 4 01:05:49 zmhost 'file' => '/var/lib/zm/www/ajax/stream.php',
Mar 4 01:05:49 zmhost 'line' => 51,
Mar 4 01:05:49 zmhost 'function' => 'ajaxError',
Mar 4 01:05:49 zmhost 'args' =>
Mar 4 01:05:49 zmhost 0 => 'socket_sendto( /var/lib/zm/socks/zms-035093s.sock ) failed: No such file or directory',
Mar 4 01:05:49 zmhost ),
Mar 4 01:05:49 zmhost 1 =>
Mar 4 01:05:49 zmhost 'file' => '/var/lib/zm/www/index.php',
Mar 4 01:05:49 zmhost 'line' => 116,
Mar 4 01:05:49 zmhost 0 => '/var/lib/zm/www/ajax/stream.php',
Mar 4 01:05:49 zmhost 'function' => 'require_once',
Mar 4 01:06:42 zmhost httpd: socket_sendto( /var/lib/zm/socks/zms-612378s.sock ) failed: No such file or directory
Mar 4 01:06:42 zmhost httpd: array (
Mar 4 01:06:42 zmhost 0 =>
Mar 4 01:06:42 zmhost array (
Mar 4 01:06:42 zmhost 'file' => '/var/lib/zm/www/ajax/stream.php',
Mar 4 01:06:42 zmhost 'line' => 51,
Mar 4 01:06:42 zmhost 'function' => 'ajaxError',
Mar 4 01:06:42 zmhost 'args' =>
Mar 4 01:06:42 zmhost 0 => 'socket_sendto( /var/lib/zm/socks/zms-612378s.sock ) failed: No such file or directory',
Mar 4 01:06:42 zmhost ),
Mar 4 01:06:42 zmhost 1 =>
Mar 4 01:06:42 zmhost 'file' => '/var/lib/zm/www/index.php',
Mar 4 01:06:42 zmhost 'line' => 116,
Mar 4 01:06:42 zmhost 0 => '/var/lib/zm/www/ajax/stream.php',
Mar 4 01:06:42 zmhost 'function' => 'require_once',
Mar 4 01:07:04 zmhost httpd: socket_sendto( /var/lib/zm/socks/zms-619271s.sock ) failed: No such file or directory
Mar 4 01:07:04 zmhost httpd: array (
Mar 4 01:07:04 zmhost 0 =>
Mar 4 01:07:04 zmhost array (
Mar 4 01:07:04 zmhost 'file' => '/var/lib/zm/www/ajax/stream.php',
Mar 4 01:07:04 zmhost 'line' => 51,
Mar 4 01:07:04 zmhost 'function' => 'ajaxError',
Mar 4 01:07:04 zmhost 'args' =>
Mar 4 01:07:04 zmhost 0 => 'socket_sendto( /var/lib/zm/socks/zms-619271s.sock ) failed: No such file or directory',
Mar 4 01:07:04 zmhost ),
Mar 4 01:07:04 zmhost 1 =>
Mar 4 01:07:04 zmhost 'file' => '/var/lib/zm/www/index.php',
Mar 4 01:07:04 zmhost 'line' => 116,
Mar 4 01:07:04 zmhost 0 => '/var/lib/zm/www/ajax/stream.php',
Mar 4 01:07:04 zmhost 'function' => 'require_once',
Mar 4 01:07:04 zmhost )"
help !
rdmelin
Post by rdmelin »
Cambozola is a java aplet, and it is installed on ZMLarch. But you will need java istalled on Windows to use iexporer with it.
Give it a try with opera. If you set CAN_STREAM = yes in the Options -> Images tab it will work with mjpeg streaming.
Also try setting MPEG_LIVE_FORMAT to swf and use mpeg streaming. This seams to work well for me with Firefox, Opera, or iexplorer6 on wine.
