Good Evening, I would ask them to please help me with the following problem:
I'm using ZoneMinder - v1.23.3 under the distribution of Linux (Ubuntu Server), My problem is that the access ZoneMinder and I try to see some camera the stream is all in blank, I want to inform them that it worked perfectly but one day to other stopped. I chek again the connection of my router and my cameras and everything is fine, in fact if I acces the cameras from their WebAdmin I can see them without any problem, I would greatly appreciate your opinions or advice.
Thankyou
Problems with stream of cameras
You mentioned that access via the "WebAdmin" works fine do you mean you are accessing ZM on the host machine via a web browser and when you try to access it from another computers browser it doesn't work. If this is the case do you currently have any authentication setup or do you just go to your ZM host ip and are presented with the normal screen listing your cameras, zones, etc?
