Yes, you've mentioned that before.
I did have to change some of them to 'at' but others worked. Then again, @ within a password delimited by =/_ shouldn't really be a problem, imho. I do understand it complicates things for your parsing attempting to hide the user/password in separate fields.
The memory fills progressively
Re: The memory fills progressively
This did fix the memory leak, no growth in 7+ hours. It also semi fixed the problem cameras. Sometimes ONVIF events are picked up.
Regards,
Mark
