The memory fills progressively
fontiano
Post by fontiano »
Debian 12 - Cpu: Ryzen 5 PRO 3400G - Ram: 32 Gb - SSD for SO and DB - HDD for events recording
After starting Zoneminder the memory occupied is approximately 3 Gb
After 6 minutes 8.44 Gb:
After 21 minutes 17.1 Gb:
After 57 minutes 32 Gb of ram and all the swap space:
All the cams are configured in the same mode:
Capturing: Always
rtsp://
Decoder: auto
Decoding: Keyframes + Ondemand
Motion Detection: Always
Analysy Image: Y-CHannel
Analysis FPS: 15
Video Writer: Camera Passthrough
SDave JPEGs: Analysis image only
Production: zm 1.34.26 - Debian 11 | Test: zm 1.36.33 - Debian 12
mikb
Re: The memory fills progressively
Post by mikb »
How many cameras do you actually have?
The count of tasks in those screen shots seems to be climbing too, is it possible you have more capture processes than you have cameras (e.g. something is causing them to stall, so ZM launches a new capture process, and again, and again, for every camera) ?
That would certainly cause you some problems.
fontiano
Post by fontiano »
No, that's the htop view.
Look @ top view:
Start:
After some minutes:
In one hour no more memory available.
EDIT:
You are right, I forgot to order by mem usage:
fontiano
Post by fontiano »
I reproduced the problem with a single camera in a VMWare machine:
Settings I'm using:
fontiano
Post by fontiano »
mikb wrote: Mon Jan 15, 2024 6:19 pm How many cameras do you actually have?
Yes, you found the problem.
11 cameras
root@zoneminder137:/usr/bin# date
mar 16 gen 2024, 18:19:54, CET
root@zoneminder137:/usr/bin# ps auxww | grep zmc | wc -l
53
mar 16 gen 2024, 18:20:01, CET
57
mar 16 gen 2024, 18:20:10, CET
57
mar 16 gen 2024, 18:20:27, CET
58
mar 16 gen 2024, 18:20:43, CET
60
mikb
Post by mikb »
OK, so at least you know what exactly you are looking to fix now ;)
Your capture processes (taking data from the camera) are not starting and running continuously. They are instead getting hung up, so ZM sees this as a fault and starts a new one -- it's persistent in trying to keep your security system running. Repeat until memory all gone.
With a single camera it would be easier to fault find -- check the ZM logs to see if it gives a clue why the zmc process isn't happy. E.g. things like analysis hasn't had a new frame for a while, or network errors causing disconnections of the camera etc.
Zm is supposed to kill processes not leave them around... This is pretty weird
fontiano
Post by fontiano »
If I launch "systemctl stop zoneminder" the command does not finish and remains hanging waiting
To make it terminate I have to kill the zmc processes with "killall -9 zmc"
I have the same problem with the same settings (with 1 cam only) in a separate test virtual machine.
Look in your logs. The answer will be there.
fontiano
Post by fontiano »
Ok, I don't know if it can be called a bug but I have identified the problem.
I had replicated the configurations identically and the zmc processes remain hanging when the command entered on "Event End Command" fails.
A simple "echo $1" generates the anomaly.
To this day I still haven't figured out how to make it work.
I recently fixed the problem with Event End Command. Please update.
marklg
Post by marklg »
It seems that zoneminder-1.37.50-1.38.20240122gitg5cc7ca28e.fc39.x86_64 still has the issue. Instances of zmc progressively take up more memory. In a few hours, it runs out of RAM and starts using Swap. Restarting Zoneminder frees up the memory.
Edit - A while after the last restart, memory usage jumped down but the overall trend it upward, with occasional small jumps down.
Regards,
Mark
I have seen many times, including lately on my own server, where slow disk writes cause this. Currently on my home server, which has been chugging along great for years, one of the drives seems to be going. SMART still says it's ok, but throughput is dropping and occasionally the raid card spits it out .
Removing it from the storage pool solves it.
Did an investigation with someone having the same issue with a brand new 18TB drive. Turns out it was an SMR drive. Shingled Magnetic Recording, on which writes are very slow.
So that is always my suspicion. Because I have spent a LOT of time trying to diagnose this over the years and I manage a lot of servers that do not have this problem.
It seems ridiculous to me though that any modern hard drive can't keep up to what is really not that much writing. If the network can keep up, the disk should be able to as well.
marklg
Post by marklg »
I am very careful to not buy SMR drives. I only have CMR and decent SSDs. This issue was not present on versions from a week or so ago.
For now, I have this in my crontab. It seems to trigger every couple hours.
5 * * * * root if [ $(grep MemFree /proc/meminfo | sed "s/[^0-9]//g") -lt 400000 ]; then /usr/bin/systemctl restart zoneminder; fi
Regards,
Mark
So.. I just found a memory leak when reloading config after a HUP. How this has escaped notice, I have NO idea. So this would have leaked 22k per camera every night.
