To build ZoneMinder yourself, see the link I gave you earlier. That is the documentation of which you speak.
It isn't going to be easy. That is the nature of the beast and is the reason why we don't encourage it.
issue building from Source on centos
- knight-of-ni
Re: issue building from Source on centos
knnniggett wrote:To build ZoneMinder yourself, see the link I gave you earlier. That is the documentation of which you speak.
okay thank you again i'll keep trying
- knight-of-ni
good luck.
Your error is caused by old ffmpeg version and a recent change to code in h264, it works with ffmpeg 3.0, but I am not sure which version it came in at the commit was end of 2014 so I assume 2.8 will have it also. Your issue will be finding that version for your chosen distro, which given it doesn't have an official ffmpeg package to start with will prove interesting.
I would help but not much use as I have never built an rpm.
SteveGilvarry wrote:Your error is caused by old ffmpeg version and a recent change to code in h264, it works with ffmpeg 3.0, but I am not sure which version it came in at the commit was end of 2014 so I assume 2.8 will have it also. Your issue will be finding that version for your chosen distro, which given it doesn't have an official ffmpeg package to start with will prove interesting.
hi,
thank you steve
i finally found the 3.0.1 i'll try
http://www.2daygeek.com/install-ffmpeg- ... -opensuse/
thanks
finally thank you guys I'll look around this and if every thing works
thanks again for your help <3
- Screenshot 2016-04-28 10.53.16.png (58.46 KiB) Viewed 2576 times
