Upload it to Dropbox/Google Drive and then a post a link to it here?melloa wrote:I've documented the steps to install ZM on FreeBSD and FreeNAS with Abi but can't attach a pdf to this forum (invalid file extension). I've posted on the FreeNAS forum but would like to have it available here as well. Any ideas how can I make this happen?
ZM on FreeBSD
- knight-of-ni
Re: ZM on FreeBSD
Re: ZM on FreeBSD
Don't like share things from my cloud, but for the love of science: https://drive.google.com/file/d/0B6clHa ... sp=sharingUpload it to Dropbox/Google Drive and then a post a link to it here?
Please test.
Re: ZM on FreeBSD
First and foremost, thank you for your exhaustive guide. Zoneminder (1.30) works under FreeBSD 10.3
In order to contribute, here the issues I had:
- 1- ZMNinja fails to Montage. I had to add a new location to the nginx.conf (step 7.2 of your procedure) as follow:
location = /cgi-bin/zms { include fastcgi_params; fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name; fastcgi_pass unix:/var/run/fcgiwrap/fcgiwrap.sock; }
- 2- API call to /api/monitors/daemonStatus/id:1 is causing a FatalErrorException. The API is used when navigating in the Monitors item in ZMNinja. The error return is:
I have yet to correct this issueCode: Select all
Error: Call to undefined function ctype_digit() File: /usr/local/www/zoneminder/api/lib/Cake/Utility/Set.php Line: 415
- 3- External trigger (zmtrigger.pl enabled via OPT_TRIGGER) is missing perl module Device::SerialPort
The perl module can be installed by doingCode: Select all
pkg install p5-App-cpanminus cpanm install Device::SerialPort
Re: ZM on FreeBSD
2. http://www.freshports.org/textproc/php56-ctype/
3. http://www.freshports.org/comms/p5-Device-SerialPort/
I'll include them in next port revision. Thanks for report.
Re: ZM on FreeBSD
(Copied from the 1.30 Support Forum)
Greetings folks, long time, no post.
I may need the assistance of ZM on FreeBSD experts on this one.
I am trying to get a USB Logitech HD Pro Webcam C920 working with ZoneMinder 1.30 on my FreeBSD 11.0 workstation at work. This is not a business related task, so it won't be earth shattering if I can't make it work. I do have the camera working with webcamd (which creates /dev/video0 as expected) and pwcview, so I know the camera does work. However, I want the control that ZM would give me.
Here are the specifics:
Here is a relevant section from the log of last Friday ('cause I removed the monitor not long after this and there is nothing relevant in the days since):
My questions:
P.S. I was told this forum thread is where all the cool kids hang out.
- FreeBSD 11.0-RELEASE x86_64
NGINX1.10.2_3,2 (installed from pkg)
ZoneMinder h264 1.30.20161104_1 (installed from pkg)
webcamd 4.8.0.4 (installed from pkg)
$ getent group webcamd
webcamd:*:145:www
2017-02-17 02:33:38.664580 zmdc 95250 ERR 'zmc -d /dev/video0' exited abnormally, exit status 255 zmdc.pl
2017-02-17 02:33:38.645311 zmc_dvideo0 101541 FAT Failed to get picture attributes: Invalid argument zm_local_camera.cpp 941
2017-02-17 02:33:38.643617 zmc_dvideo0 101541 INF Starting Capture version 1.30.0 zmc.cpp 250
2017-02-17 02:33:38.635208 zmc_dvideo0 101541 INF No direct match for the selected palette and target colorspace. Format conversion is required, performance penalty expected zm_local_camera.cpp 551
2017-02-17 02:33:38.084850 zmdc 96408 INF 'zmc -d /dev/video0' started at 17/02/16 17:33:38 zmdc.pl
2017-02-17 02:33:38.084670 zmdc 95250 INF 'zmc -d /dev/video0' starting at 17/02/16 17:33:38, pid = 96408 zmdc.pl
2017-02-17 02:33:38.082070 zmdc 95250 INF Starting pending process, zmc -d /dev/video0 zmdc.pl
2017-02-17 02:33:33.259660 zmfilter 96400 INF Scanning for events zmfilter.pl
- Should I expect ZM on FreeBSD to work with the /dev/video0 device created by webcamd?
- If not, what should I be using instead of the webcamd daemon?
- Should I expect a USB webcam to work with ZM on FreeBSD? Is that something that is supported?
Re: ZM on FreeBSD
just get a network camera which works with FreeBSD, lots of work, patience and possibly pray. Webcam?? The chances are small.
Re: ZM on FreeBSD
Yeah ... no. I am not going to buy a network camera just for this. If it were something work related that had to be working with ZM, then I would probably get an Axis and be done with it. But this is a "free" webcam that was given to me that I am just playing around with.
That said, if there is a way to make it work with ZM on FreeBSD, even if it requires some effort, I would like to do that for the learning experience if nothing else. So, I am still open to suggestions for getting the webcam working with ZM here.
Thanks for the reply none the less.
Re: ZM on FreeBSD
back in the day (2007?) when I got my hands dirty porting the ZM linux camera code to FreeBSD ZM (was it 1.23?) with the bktr driver, it was a lot of work. Later when I tried porting 1.25, touching the local camera was out of the question - it was getting harder to understand the code. Now I guess I would not touch anything.
Is there any service on FreeBSD that would serve webcamd via e.g. http? If so, your chances are getting bigger.
- knight-of-ni
Re: ZM on FreeBSD
I would like here from abi, the maintainer of the current port, to see what he might have done to handle local video devices on FreeBSD.
He pops in from time to time. He might not have touched this part of zoneminder, but it would be good to know that.
That would at least help define what exactly still needs to be done.
Re: ZM on FreeBSD
Browsing here : https://svnweb.freebsd.org/ports/head/m ... rtdir=down I don't think there is any local camera code ported. When bsam took over he didn't even own a camera. I don't know the status with abi.
What's the status of v4l on FreeBSD?
Re: ZM on FreeBSD
I disabled local code in default package because it left untested as I don't have any USB cameras. You need to compile ZM from ports with V4L knob on.(installed from pkg)
Re: ZM on FreeBSD
Ah, okay. That will have to wait a bit. I will report back once I try that. Thanks!abi wrote:I disabled local code in default package because it left untested as I don't have any USB cameras. You need to compile ZM from ports with V4L knob on.(installed from pkg)
Re: ZM on FreeBSD
Thanks Bro! For the love of science!melloa wrote: ↑Tue Jul 05, 2016 6:24 pmDon't like share things from my cloud, but for the love of science: https://drive.google.com/file/d/0B6clHa ... sp=sharingUpload it to Dropbox/Google Drive and then a post a link to it here?
Please test.
Cheers!
Paul Jones
http://www.stlouiscitytowing.com/
Re: ZM on FreeBSD
Hi Guys,
finally I installed ZoneMinder on my FreeBSD/FreeNAS box. And it works great. Now I would like to customize it a bit, putting control GUI for the PTZ functions as described in the wiki https://wiki.zoneminder.com/Foscam_Clones.
The problem is reated to different path of the filesystem between Ubuntu and FreeBSD. Does anyeone know the correct path where to put scripts of zoneminder under FreeBSD installation?
Thnak you so much
Thnak you so much
Re: ZM on FreeBSD
vendor_perl under FreeBSD is /usr/local/lib/perl5/site_perl
