live veiw YES on localhost, NO on others
zd59
Post by zd59 »
Hello!
My config:
Zoneminder-1.30 on Debian stretch ( 4.8.0-2-amd64 #1 SMP Debian 4.8.11-1 (2016-12-02) x86_64 GNU/Linux)
Apache/2.4.25
The problem:
All works on localhost, whrere all is installed. I can watch live video and events video in Firefox, none in Konquerror.
The problem is, that live video can not play on other computers on LAN, but events video plays OK. Tried Firefox on Linux (slackware) and Firefox & internet Explorer on Windows. Internet Explorer give me a Java app security approval window, and after click to run I get "Java.net.UnknownHostException:HOSTNAME" error in the place of a video window. The same case is on my Android phone (live or event video not working).
I Cambozolla.jar is at right place with right permissions (0755)
PATH_ZMS = /zm/cgi-bin/nph-zms which is in zoneminder.conf:
AllowOverride All
Require all granted
</Directory>
<IfModule mod_dir.c>
DirectoryIndex index.php
</IfModule>
</Directory>
AllowOverride All
</Directory>
MPEG_LIVE_FORMAT = tested mpg mpeg wmv asf avi mov swf 3gp mp4
WEB_H_CAN_STREAM = tested Auto, yes, none
WEB_H_STREAM_METHOD = tested mpeg, jpeg
Loglevels:
LOG_LEVEL_SYSLOG, LOG_LEVEL_DATABASE = info, others none
log window in zoneminder gui console & logs in /var/log/apache2 show no signs of errors.
Must point out, that none of the browsers (Firefox or IE) warns about any missing plugins.
Any idea, what to try?
regards to Zoneminder developers & comunity, incredible work done!
Re: live veiw YES on localhost, NO on others
Check the Apache /etc/apache2/sites-enabled directory that you have a correct virtual host configuration to allow Apache to serve the ZM streams by setting the right permissions for the /cgi-bin when accessed via LAN or Internet and not just localhost.
zd59
Post by zd59 »
Thank's for a tip.
Regarding configuration files & permissions are below.
/etc/apache2/sites-enabled 000-default.conf -> ../sites-available/000-default.conf -rw-r--r-- root root
the not commented contents of above file
ServerAdmin webmaster@localhost
DocumentRoot /var/www/html
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
/etc/apache2/conf-enabled/ zoneminder.conf -> ../conf-available/zoneminder.conf -rw-r--r-- 1 root root
AllowOverride All
Require all granted
</Directory>
</IfModule>
</Directory>
AllowOverride All
</Directory>
/etc/apache2/conf-enabled/serve-cgi-bin.conf serve-cgi-bin.conf -> ../conf-available/serve-cgi-bin.conf -rw-r--r-- 1 root root
<IfModule mod_alias.c>
<IfModule mod_cgi.c>
Define ENABLE_USR_LIB_CGI_BIN
</IfModule>
<IfModule mod_cgid.c>
</IfModule>
<IfDefine ENABLE_USR_LIB_CGI_BIN>
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin">
AllowOverride None
Require all granted
</Directory>
</IfDefine>
</IfModule>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
permissions of files:
/usr/lib/zoneminder/cgi-bin
lrwxrwxrwx 1 root root 3 Dec 10 03:20 nph-zms -> zms
-rwxr-xr-x 1 root root 1269024 Dec 10 03:20 zms
/usr/lib/cgi-bin/
-rwxr-xr-x 1 root root 122432 Aug 4 07:05 htsearch
-rwxr-xr-x 1 root root 56216 Aug 4 07:05 qtest
Also checked again: no lines regarding video stream error/warning in apache2 error.log access.log or zoneminder log screen.
The only sign of video watch request was in /var/log/apache2/access.log:
10.200.200.10 - - [19/Jan/2017:09:48:51 +0100] "GET /zm/index.php?view=watch&mid=2 HTTP/1.1" 200 2532 "http://10.200.200.20/zm/index.php" "Mozilla/5.0 (Windows NT 10.0; WOW64; rv:50.0) Gecko/20100101 Firefox/50.0"
The apache2 LogLevel warn
The system log (/var/log/system) also logs (LOG_LEVEL_SYSLOG = INFO) and there is no sign of any warning or error. Just Capturing and Analysing lines.
What bothers me the most is the fact, that I can watch events video and NOT live video. What is the difference between both, if I set the same settings in options -> images in Zoneminder console settings?
Regards!
I think you are "stretching" things a bit trying to get a development version to work. However, I am in process of loading up Stretch to see what I can come up with. Stay tuned...
try using this in /etc/apache2/sites-enabled 000-default.conf -> ../sites-available/000-default.conf
AddHandler cgi-script .cgi .pl
Since it works with localhost it could be that /cgi-bin is not configured to be accessible via network.
Or in your PATHS config in ZM Options is not set to the correct /cgi-bin
It could be that it is using the wrong alias /cgi-bin..... you have two.
Well, my test install works just fine. I did not set up a desktop version and did the bulk of the Zoneminder install from Putty on a Windows PC. I suspect you used a desktop install which may contain a firewall that is causing your issues.
Here are the basic steps I used:
Debian 9 LAMP Zoneminder
net install CD install only web server, SSH server and standard system utilities from tasksel
Login and become root
Install additional LAMP components
apt install apache2 php mysql-server php-mysql
Install Zoneminder
apt-get install zoneminder
mysqladmin -uroot -p reload
chmod 740 /etc/zm/zm.conf
adduser www-data video
Start Zoneminder
a2enmod cgi
a2enmod rewrite
a2enconf zoneminder
Add timezone to PHP
[Date]
Ctrl+o Enter to save
CTRL+x to exit
Restart Apache
service apache2 restart
Had to make an addition to my procedure to get the API to work. See:
https://wiki.zoneminder.com/Debian_9_64 ... e_Easy_Way
zd59
Post by zd59 »
rockedge wrote:try using this in /etc/apache2/sites-enabled 000-default.conf -> ../sites-available/000-default.conf
Thank you rockedge for the tips.
Changes you suggested did not helped.
I do not have any firewall on the server nor on client - home LAN clean, firewall on the WAN router only.
After applying your suggestions and restarting apache2 & zoneminder, I found some errors in zoneminder log regarding streaming.
Maybe this is the key.
ZM LOG:
2017-01-20 11:51:43.554220 zma_m2 28672 INF Vhod: 3000 - Analysing at 10.00 fps zm_monitor.cpp 1287
2017-01-20 11:51:38.532865 zmc_m2 28639 INF Vhod: 3000 - Capturing at 10.00 fps zm_monitor.cpp 3116
2017-01-20 11:50:14.442883 zms 28709 ERR Unable to send stream frame: Broken pipe zm_event.cpp 1348
2017-01-20 11:50:14.253378 zms 28709 INF Got signal 15 (Terminated), exiting zm_signal.cpp 40
2017-01-20 11:48:23.273902 zma_m2 28672 INF Vhod: 1000 - Analysing at 10.00 fps zm_monitor.cpp 1287
2017-01-20 11:48:18.545776 zmc_m2 28639 INF Vhod: 1000 - Capturing at 10.00 fps zm_monitor.cpp 3116
2017-01-20 11:46:43.233928 zma_m2 28672 INF Analysis fps (20.00) is lower than capturing fps (25.52), disabling adaptive skip feature zm_monitor.cpp 880
2017-01-20 11:46:43.213564 zma_m2 28672 INF In mode 3/1, warming up zma.cpp 142
2017-01-20 11:46:43.059540 zmdc 28672 INF 'zma -m 2' started at 17/01/20 11:46:43 zmdc.pl
2017-01-20 11:46:43.059530 zmdc 28609 INF 'zma -m 2' starting at 17/01/20 11:46:43, pid = 28672 zmdc.pl
2017-01-20 11:46:43.015420 zmdc 28609 INF Starting pending process, zma -m 2 zmdc.pl
2017-01-20 11:46:38.664370 zmwatch 28660 INF Watchdog pausing for 30 seconds zmwatch.pl
2017-01-20 11:46:38.602740 zmwatch 28660 INF Watchdog starting zmwatch.pl
2017-01-20 11:46:38.425830 zmdc 28660 INF 'zmwatch.pl' started at 17/01/20 11:46:38 zmdc.pl
2017-01-20 11:46:38.425820 zmdc 28609 INF 'zmwatch.pl' starting at 17/01/20 11:46:38, pid = 28660 zmdc.pl
2017-01-20 11:46:38.296210 zmfilter 28649 INF Scanning for events zmfilter.pl
2017-01-20 11:46:38.248970 zmdc 28654 INF 'zmaudit.pl -c' started at 17/01/20 11:46:38 zmdc.pl
2017-01-20 11:46:38.248970 zmdc 28609 INF 'zmaudit.pl -c' starting at 17/01/20 11:46:38, pid = 28654 zmdc.pl
2017-01-20 11:46:38.220327 zmc_m2 28639 INF Priming capture from rtsp://admin:only4ZD59@10.200.200.111/2?tcp zm_ffmpeg_camera.cpp 104
2017-01-20 11:46:38.188984 zmc_m2 28639 INF Starting Capture version 1.30.0 zmc.cpp 250
2017-01-20 11:46:38.097310 zmdc 28609 ERR 'zma -m 2' exited abnormally, exit status 255 zmdc.pl
2017-01-20 11:46:38.068823 zma_m2 28648 ERR Shared data not initialised by capture daemon for monitor Vhod zm_monitor.cpp 442
2017-01-20 11:46:38.045910 zmdc 28609 INF 'zmfilter.pl' starting at 17/01/20 11:46:38, pid = 28649 zmdc.pl
2017-01-20 11:46:38.045910 zmdc 28649 INF 'zmfilter.pl' started at 17/01/20 11:46:38 zmdc.pl
2017-01-20 11:46:38.020490 zmdc 28648 INF 'zma -m 2' started at 17/01/20 11:46:38 zmdc.pl
2017-01-20 11:46:38.020440 zmdc 28609 INF 'zma -m 2' starting at 17/01/20 11:46:38, pid = 28648 zmdc.pl
2017-01-20 11:46:37.993770 zmdc 28609 INF Starting pending process, zma -m 2 zmdc.pl
2017-01-20 11:46:37.953740 zmdc 28609 ERR 'zma -m 2' exited abnormally, exit status 255 zmdc.pl
2017-01-20 11:46:37.926059 zma_m2 28641 ERR Shared data not initialised by capture daemon for monitor Vhod zm_monitor.cpp 442
2017-01-20 11:46:37.868420 zmdc 28609 INF 'zma -m 2' starting at 17/01/20 11:46:37, pid = 28641 zmdc.pl
2017-01-20 11:46:37.868420 zmdc 28641 INF 'zma -m 2' started at 17/01/20 11:46:37 zmdc.pl
2017-01-20 11:46:37.785900 zmdc 28639 INF 'zmc -m 2' started at 17/01/20 11:46:37 zmdc.pl
2017-01-20 11:46:37.785890 zmdc 28609 INF 'zmc -m 2' starting at 17/01/20 11:46:37, pid = 28639 zmdc.pl
2017-01-20 11:46:37.758870 zmdc 28609 INF Starting pending process, zmc -m 2 zmdc.pl
2017-01-20 11:46:37.737990 zmdc 28609 ERR 'zmc -m 2' exited abnormally, exit status 255 zmdc.pl
2017-01-20 11:46:37.594150 zmdc 28635 INF 'zmc -m 2' started at 17/01/20 11:46:37 zmdc.pl
2017-01-20 11:46:37.594120 zmdc 28609 INF 'zmc -m 2' starting at 17/01/20 11:46:37, pid = 28635 zmdc.pl
2017-01-20 11:46:37.395750 zmpkg 28595 INF Single server configuration detected. Starting up services. zmpkg.pl
2017-01-20 11:46:34.390310 zmdc 28609 INF Server starting at 17/01/20 11:46:34 zmdc.pl
2017-01-20 11:46:33.989470 zmpkg 28595 INF Command: start zmpkg.pl
2017-01-20 11:46:33.951250 zmpkg 28595 INF Sanity checking States table... zmpkg.pl
2017-01-20 11:46:33.691490 zmsystemctl 28591 INF Redirecting command through systemctl zmsystemctl.pl
2017-01-20 11:46:33.505000 zmpkg 28585 INF Command: start zmpkg.pl
PATH_MAP=PATH_SWAP=/dev/shm
Filesystem Size Used Avail Use% Mounted on
udev 4.1G 0 4.1G 0% /dev
tmpfs 807M 86M 721M 11% /run
/dev/sda1 152G 14G 131G 10% /
tmpfs 4.1G 958M 3.1G 24% /dev/shm
tmpfs 5.3M 4.1k 5.3M 1% /run/lock
tmpfs 4.1G 0 4.1G 0% /sys/fs/cgroup
tmpfs 807M 13k 807M 1% /run/user/1001
root@video-nadzor:/etc/apache2/conf-available# ls -la /dev/shm
total 934624
drwxrwxrwt 2 root root 20060 Jan 20 11:46 .
drwxr-xr-x 20 root root 3360 Jan 13 18:25 ..
-rw------- 1 www-data www-data 737281760 Jan 20 11:46 zm.mmap.2
-rw-r--r-- 1 www-data www-data 209852 Jan 18 19:00 zmswap-i00000.jpg
-rw-r--r-- 1 www-data www-data 210813 Jan 18 19:00 zmswap-i00001.jpg
and many more swap files. I think, they were created on sucessfull live view on localhost only. Today I checked, were not created on remote access.
Thank you for your time.
Regarding above, have you any new advice?
Regrads!
reinstall Debian and use the new instructions on the WIKI for Debian 9
zd59
Post by zd59 »
Hello again!
Discovered very strange behaviour, and so a partial solution to the problem described at my first post.
The member of this post "Basketcase" on Tue Oct 18, 2016 8:41 am posted:
viewtopic.php?f=36&t=25382&p=97008&hili ... eam#p97008
Between the lines I found out, that CGI script, that is responsible for a streaming a live video works coorectly only when in the browser the URL for the zoneminder is its name. When you write IP instead of a name, there is no live video stream.
As I do not have a DNS at home, I had always written IP (http://10.200.200.200/zm).
As the problem is mentioned in the post above, I set a line in a host file (10.200.200.200 video-surveillance) on remote computer, then in Firefox http://video-surveillance/zm, and miraculously now I can watch live video from camera.
In the servers option in zoneminder there must be a line with a server name, in my case "video-surveillance", and user authentication in zoneminder must be OFF.
Hope that one of the developers will read this post, to correct this misbehavior. At this point I can not watch live video on Android, as host file is not accesible.
Greetings to all.
zd59
Post by zd59 »
Hi!
Developers: no answers for the above?
Simple question: why no live video, if Zoneminder is addressed by IP instead of its name in web browser?
No home DNS, so if hosts file "resolve" IP to name, then live video works in browser. This can not be done on Android without rooting it. So no solution for Android.
Regards.
I still think you need to configure the web server correctly. The line you wrote
leads me to believe you configured the virtual users block incorrectly. Or you are using the multi-server options? Because it is confusing as to what is going wrong as you describe it.
SteveGilvarry
Post by SteveGilvarry »
Zd59 I will try and replicate, to confirm http://localhost works but http://xxx.xxx.xxx.xxx doesn't? I normally only use the IP and don't have a localhost GUI. On my phone at the moment but I assume all your apache conf is above, if not can you add it.
Steve
zd59
Post by zd59 »
Hello!
I attached apache2.conf - the same as installed by corresponding Debian 8 package and (if) changed by zoneminder 1.30 installation/configuration.
Rem: .txt at the end as forum do not accept attacments ending ".conf"
The below are untached files as installed and configured by corresponding packages installed and configured by ZM.
root@video-nadzor:/etc# ls -la apache2/conf-enabled
total 8
drwxr-xr-x 2 root root 4096 Jan 6 23:38 .
drwxr-xr-x 8 root root 4096 Jan 29 12:55 ..
lrwxrwxrwx 1 root root 30 Jan 6 23:26 adminer.conf -> ../conf-available/adminer.conf
lrwxrwxrwx 1 root root 30 Jan 6 17:49 charset.conf -> ../conf-available/charset.conf
lrwxrwxrwx 1 root root 44 Jan 6 17:49 localized-error-pages.conf -> ../conf-available/localized-error-pages.conf
lrwxrwxrwx 1 root root 46 Jan 6 17:49 other-vhosts-access-log.conf -> ../conf-available/other-vhosts-access-log.conf
lrwxrwxrwx 1 root root 33 Jan 6 23:38 phpmyadmin.conf -> ../conf-available/phpmyadmin.conf
lrwxrwxrwx 1 root root 31 Jan 6 17:49 security.conf -> ../conf-available/security.conf
lrwxrwxrwx 1 root root 36 Jan 6 17:49 serve-cgi-bin.conf -> ../conf-available/serve-cgi-bin.conf
lrwxrwxrwx 1 root root 33 Jan 6 18:46 zoneminder.conf -> ../conf-available/zoneminder.conf
Pointing out, that this machine is dedicated to ZM and no other packages were installed to spoil Apache or else.
Regards!
apache2.conf.txt
(7.22 KiB) Downloaded 306 times
SteveGilvarry
Unless you have multiple servers it should be blank. I am concerned you have turned all the knobs and dials now so getting you back to a default configuration, which with Firefox should work fine. I don't promise anything works on IE. Might be an idea to start over and don't change anything not in BBunge's wiki guide.
