No Log
Dalius
No Log
Post by Dalius »
Hi there
Log window is empty:-(
Couldn't find any decent suggestion on the board - so am asking for a help here again;-)
Distro: Ubuntu 14.04.1
Any ideas?
Cheers,
D.
PacoLM
Re: No Log
Post by PacoLM »
Is the logging enabled?
LOG_LEVEL_SYSLOG, LOG_LEVEL_FILE, LOG_LEVEL_WEBLOG and LOG_LEVEL_DATABASE are set to something different than None?
Dalius
Re: No Log
Post by Dalius »
LOG_LEVEL_SYSLOG - Info
LOG_LEVEL_FILE- none
LOG_LEVEL_WEBLOG - none
LOG_LEVEL_DATABASE - info
Re: No Log
Check these install instructions to see if you missed something: https://wiki.zoneminder.com/Ubuntu_Serv ... e_easy_way
Dalius
Re: No Log
Post by Dalius »
thanks a lot but...
double checked - all was there, except the delay... entered that, restarted zoneminder service manually - still no LOG entries appear:-(
Dalius
Re: No Log
Post by Dalius »
No more ideas? Would like to sort this out cause I have a much bigger problem: video stream disappears / becomes blue after a while... Can't figure out what's there happening because have no log:-(
DanCoco
Re: No Log
Post by DanCoco »
I resolved this by going into the logs table of the database and clearing it. The logs returned shortly afterward. Try a reboot after clearing.
