Unable to install ZM on CentOS - Missing Perl Packages
cparent79
Post by cparent79 »
Hi everyone, I'm new here, but not new to linux. I'm wondering if I'm missing some key detail here. I thought the ZMRepo was a complete turnkey solution. I've got a fresh minimal install of CentOS 7 (also tried on fedora and OEL 6 and 7 distros) I'm receiving an error that certain perl packages are missing during the install -
---> Package perl-Class-Load.noarch 0:0.10-1.el6 will be installed
--> Processing Dependency: perl(Try::Tiny) for package: perl-Class-Load-0.10-1.el6.noarch
--> Processing Dependency: perl(Package::Stash) for package: perl-Class-Load-0.10-1.el6.noarch
---> Package perl-Params-Util.x86_64 0:1.00-3.el6 will be installed
---> Package perl-Sub-Install.noarch 0:0.925-6.el6 will be installed
--> Finished Dependency Resolution
Error: Package: perl-Class-Load-0.10-1.el6.noarch (zmrepo)
           Requires: perl(Package::Stash)
           Requires: perl(Try::Tiny)
 You could try using --skip-broken to work around the problem
 You could try running: rpm -Va --nofiles --nodigest
I didn't see a list of required packages mentioned on https://zmrepo.zoneminder.com/.
I tried adding the required packages using cpan but it just turned into one broken dependency mess after another.
Any guidance greatly appreciated.
Thank you
cparent79
Re: Unable to install ZM on CentOS - Missing Perl Packages
Post by cparent79 »
DISREGARD. I'm an idiot. All is well :)
GAC
Post by GAC »
What was your solution, I have exactly the same issue.
Thanks,
GAC
The packages yum claims are missing can be found in the base CentOS repository. This is the repository that comes preconfigured with every default installation of CentOS.
GAC
Post by GAC »
I had the default repositories but somehow i got those errors. Solved by adding the epel repository
yum install epel-release
Something else I noticed, the OP claims to be running CentOS7 (el7) but his yum output is from a machine running CentOS6 (el6)
This does not add up.
