could not open configuration file
iitywygms
Post by iitywygms »
Went to open webpage and got nothing but this.
Could not open config file.
Ubuntu 14.04
Latest version from icconer ppa.
I can see zoneminder running I just cant open the web page.
Is this something I can easily fix or do I need to do a fresh install again?
Re: could not open configuration file
Recommend you check your install steps:
iitywygms
Post by iitywygms »
I did do that
after this happened. It worked for the last few days but today I got this error. I changed nothing.
iitywygms
Post by iitywygms »
Did a purge and reintall. Doing so fixed this issue.
