Cannot create JPEGs with v1.28.1/Ubuntu 14.04/FI8918W
I'm trying to run ZoneMinder v1.28.1 on a very basic setup: a fresh install of Ubuntu 14.04 and a single Foscam FI8918W connected over ethernet. ZM is installed from Isaac Connor's PPA. The webcam works fine, I can use its web-based interface without problems. After I set up the camera in ZM, it appears to connect to the camera but cannot create JPEG images. All configuration in ZM is using the defaults. The logs contain:
Unable to decode jpeg
Failed requesting writeable buffer for reading JPEG image.
Held buffer is undersized for requested buffer
The URL in the camera setup (/snapshot.cgi?user=alice&pwd=secret) works fine when using a web browser.
I suspect there is an issue with how shared memory is being handled. Anybody know how to fix this?
Thanks,
Larry
Thanks,
Larry
Re: Cannot create JPEGs with v1.28.1/Ubuntu 14.04/FI8918W
Before we debug other aspects, can you try the following instead of snapshot.cgi
General Tab:
Source Type: FFMpeg
Source Tab:
Source Path:
http://camip/videostream.cgi?user=xxx&pwd=yyy (replace xxx/yyy/camip)
Remote Method:
RTP/RTP/HTTP
colorspace: 24bit
Width/Height:640x480
General Tab:
Source Type: FFMpeg
Source Tab:
Source Path:
Remote Method:
RTP/RTP/HTTP
colorspace: 24bit
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
- knight-of-ni
Please follow the programming documentation for this camera here:
http://www.zoneminder.com/wiki/index.php/Foscam_FI8918W
When I change the URL to videostream.cgi, ZM appears to connect to the webcam, but the monitor doesn't display any images. The logs say
getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-085101s.sock ) failed: No such file or directory - checkStreamForErrors() socket_sendto( /var/run/zm/zms-085101s.sock ) failed: No such file or directory
atlas-lab: 46000 - Capturing at 1000.00 fps
atlas-lab: 45000 - Capturing at 1000.00 fps
I tried following the instructions on the page that knnniggett posted, but when I add a new monitor I do not see a "Control" tab, only General/Source/Timestamp/Buffers/Misc.
Thanks,
Larry
Thanks,
Larry
- knight-of-ni
Ignore this for now, until we fix the other message:
Also, use something like VLC to verify the url you are using in zoneminder.
This means your backend is not working. Make sure you are not accessing the camera's web page at the same time you are trying to view it in ZoneMinder. Try the test again, and wait a little longer. Do not try to view the monitor in ZoneMinder and just watch the logs. You are looking for "Capturing at x.xx fps" where x.xx matches the frame rate in your camera, or a new error message appears.ldenneau wrote: getStreamCmdResponse stream error: socket_sendto( /var/run/zm/zms-085101s.sock ) failed: No such file or directory - checkStreamForErrors() socket_sendto( /var/run/zm/zms-085101s.sock ) failed: No such file or directory
You have to turn on PTZ control under Options first before the tab will appear.ldenneau wrote: atlas-lab: 46000 - Capturing at 1000.00 fps
ldenneau wrote: I tried following the instructions on the page that knnniggett posted, but when I add a new monitor I do not see a "Control" tab, only General/Source/Timestamp/Buffers/Misc.
Please review these instructions to see if you skipped something in your setup:
http://www.zoneminder.com/wiki/index.ph ... e_easy_way
For your monitor:
Source Type: Remote
Function: (your choice but start with Monitor)
Remote Protocol: HTTP
Remote Method: Simple
Remote Host Name: (camera IP)
Remote Host Port: 80
Remote Host Path: /videostream.cgi?user=admin&pwd=(password)&rate=11
Capture Width: 320
Capture Height: 240
I have two of these cameras running with these settings. The &rate=11 will give you 5 FPS.
Control gets a bit complicated. Get the video to work then attack control from the procedure in this forum.
For your monitor:
Source Type: Remote
Capture Width: 320
Capture Height: 240
I tried this originally, except using snapshot.cgi. If I use videostream.cgi, I get the same errors that I mentioned at the beginning of this thread ("unable to decode JPEG"). The webcam works fine through a web browser and VLC.bbunge wrote:Please review these instructions to see if you skipped something in your setup:
For your monitor:
Source Type: Remote
Capture Width: 320
Capture Height: 240
I don't care about control at this point; I'd just like to see the images in the ZM monitor.
Did you review the install instructions? You may want to start over with a fresh install of Ubuntu server or try another camera. Also make sure you are using the correct port that your camera uses. I set my cameras to use port 80 but yours may use port 88 (Foscam default for some cameras).
ZM is installed on a fresh Ubuntu 14.04 install already. I've gone through about three different sets of install instructions, all slightly different. None of them produce a working ZM. This is about the most basic setup I can imagine.bbunge wrote:Did you review the install instructions? You may want to start over with a fresh install of Ubuntu server or try another camera. Also make sure you are using the correct port that your camera uses. I set my cameras to use port 80 but yours may use port 88 (Foscam default for some cameras).
I've deployed about a half-dozen of these cameras in a remote telescope environment. We are able to operate them over the web or with VLC through SSH tunnels. I know how to set them up. I am simply trying to get ZM running on a dedicated Ubuntu 14.04 computer talking to a FI8918W in my office so that we can do some security monitoring.
Thanks,
Larry
Okay, I have the same camera. So let's see if I can help.
Questions (not all of them may be directly relevant to your problem)
1. Launch a terminal and let me know the output of
2. Please post a screenshot of how you have configured the camera in ZM - please post an image of the General/Source/Buffers tabs
3. What sort of a server specs are you running ZM on? What is the average load?
df -h
ES docs
zmNinja docs
ES docs
zmNinja docs
Hmm...
I periodically check my install procedure to make sure someone has not changed it and that it still works! I went through the install for 1.28.1 on 14.04-3 a week ago and it was OK...
So, start with a fresh Ubuntu server install and just install LAMP from tasksel.
Next follow the install steps beginning with Enable CGI in Apache2 from this web page in the ZM WIKI:
You do not have to make the changes to MySQL or add cambozola
Think I may have given you the setup for a FI9810W camera. It should be the same as the "18" and if you can get it to work in VLC use the same info in ZM and use Ffmpeg. You could try Libvlc but I've not had much success with it.
asker likely has the best info on the camera...
Oh...if you do not get the HxW settings right your video will never work.
bb
bb
I reinstalled Ubuntu 14.04 server 64-bit and followed bbunge's install instructions to the letter. So it's a totally virgin system, no disk used, no extra processes, and same results. When using SourceType=Remote/Method=Simple/snapshot.cgi, the log messages say
over and over. When I using SourceType=Ffmpeg/videostream.cgi?rate=11, I see alot of
If I bring up the monitor I see a blue screen with running time at the top left.
The system is a modern LogicSupply industrial computer with 2 1GHz Celeron cores, 4GB RAM, 60GB SSD. This computer ran an astronomical telescope flawlessly for about a year, so the computer is fine. The Foscam webcam works fine over HTTP or VLC.
The ZM board won't let me attach a file, so I put screenshots of the monitor settings here: http://goo.gl/Y03INZ
Thanks for your help folks. I'd dig into the source code myself to debug but I simply don't have the time.
Larry
lab: 39000 - Capturing at 1000.00 fps
Shared data not initialised by capture daemon, some query functions may not be available or produce invalid results for monitor lab
$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mapper/merch--vg-root 54G 2.5G 49G 5% /
none 4.0K 0 4.0K 0% /sys/fs/cgroup
udev 1.9G 12K 1.9G 1% /dev
tmpfs 389M 560K 388M 1% /run
none 5.0M 0 5.0M 0% /run/lock
none 1.9G 22M 1.9G 2% /run/shm
none 100M 0 100M 0% /run/user
/dev/sda2 237M 80M 145M 36% /boot
/dev/sda1 511M 3.4M 508M 1% /boot/efi
$ w
15:36:31 up 2 days, 2:27, 2 users, load average: 1.19, 0.96, 0.47
USER TTY FROM LOGIN@ IDLE JCPU PCPU WHAT
atlas tty1 Tue13 2days 0.14s 0.11s -bash
atlas pts/0 cadeo.ifa.hawaii 15:35 7.00s 0.11s 0.00s w
$ top -b -n 1 | head -30
top - 15:49:09 up 2 days, 2:40, 2 users, load average: 1.10, 1.00, 0.76
Tasks: 113 total, 2 running, 111 sleeping, 0 stopped, 0 zombie
%Cpu(s): 0.7 us, 0.3 sy, 0.0 ni, 98.8 id, 0.1 wa, 0.0 hi, 0.0 si, 0.0 st
KiB Mem: 3974600 total, 2719668 used, 1254932 free, 209188 buffers
KiB Swap: 4116476 total, 0 used, 4116476 free. 2045144 cached Mem
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
565 www-data 20 0 351452 23708 15540 R 102.4 0.6 0:36.35 zmc
1 root 20 0 36548 5876 1544 S 0.0 0.1 0:34.79 init
2 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kthreadd
3 root 20 0 0 0 0 S 0.0 0.0 0:00.89 ksoftirqd/0
4 root 20 0 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0
5 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/0:0H
7 root 20 0 0 0 0 S 0.0 0.0 0:16.10 rcu_sched
8 root 20 0 0 0 0 S 0.0 0.0 0:14.47 rcuos/0
9 root 20 0 0 0 0 S 0.0 0.0 0:17.65 rcuos/1
10 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcu_bh
11 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcuob/0
12 root 20 0 0 0 0 S 0.0 0.0 0:00.00 rcuob/1
13 root rt 0 0 0 0 S 0.0 0.0 0:00.51 migration/0
14 root rt 0 0 0 0 S 0.0 0.0 0:01.51 watchdog/0
15 root rt 0 0 0 0 S 0.0 0.0 0:01.51 watchdog/1
16 root rt 0 0 0 0 S 0.0 0.0 0:00.59 migration/1
17 root 20 0 0 0 0 S 0.0 0.0 0:00.51 ksoftirqd/1
19 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kworker/1:0H
20 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 khelper
21 root 20 0 0 0 0 S 0.0 0.0 0:01.79 kdevtmpfs
22 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 netns
23 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 writeback
24 root 0 -20 0 0 0 S 0.0 0.0 0:00.00 kintegrityd
Larry
- knight-of-ni
Your source path is incorrect. Notice that you have not told ZoneMinder the ip address nor the protocol to use in your screenshot. It has no way to connect to the camera in question.
Also note that the resolution you state in ZoneMinder has to match the resolution in the camera, exactly.
If you use videostream.cgi, your source type should be remote according to the wiki. See the link referenced earlier:When I using SourceType=Ffmpeg/videostream.cgi?rate=11, I see alot of
I also posted this in the 1.26.x area.
One more time!
I had my production server hard drive crash the other day. So, with a new WD drive I set about installing Ubuntu 14.04 with ZM 1.28.1 from the PPA. Everything went well until I got to the Foscam FI8910W.
I set it up as remote with Remote Host Path of: /videostream.cgi?user=visitor&pwd=visitor1
The camera has an "Operator" of visitor.
And ZM wold not connect to the camera and work!
What did work was to use the camera administrator user and password like: /videostream.cgi?user=admin&pwd=password1
Additionally I added &rate=11 to the end of the line to lower the camera frame rate to 5 FPS.
Since the FI8918W and FI8910W are reported to have the same settings it should now work for you.
One more time!
