geovision GV-1480
giloosh
geovision GV-1480
Post by giloosh » Mon Oct 19, 2009 1:12 pm
I am trying to get the geovision GV-1480 card to work in zoneminder.
http://www.amazon.com/gp/product/B000RLXDRE
I have decided to convert from windows XP to a linux zoneminder rig. I installed the latest ZMlarch. I ran a lspci and saw one pci card that might be the one called "Multimedia video controller" but I am not finding any /dev/video devices. I did follow this thread http://www.zoneminder.com/forums/viewtopic.php?p=55361 and updated my kernel (by running pacman -Syu), but still the same thing, no /dev/video devices. I would like this work before having to go out abd buy new cards, so if anyone could help that would be much appreciated.
thanks!
HellMind
Post by HellMind » Tue Apr 20, 2010 4:46 pm
Did you try it?
I need a 16 ch 400 fps board, and that one is the only I can get in my country
rangerbob
Re: geovision GV-1480
Post by rangerbob » Tue May 26, 2015 3:11 pm
I too want a 400fps type card that works with linux can someone show us the
lspci -vvv
on it under linux with a v3 kernel
it would be nice to know what the chips say on it. might need some sort of special driver before things start to show. can anyone tell us anything about!?
marcom
Post by marcom » Fri Aug 21, 2015 12:00 pm
Is there a 400 fps card ? A link pls ...
marcom
Post by marcom » Fri Aug 21, 2015 12:52 pm
Here is a link for the GeoVision 400 fps card ..
GV-5016
Interface PCI-E (x1)
Input Type LFH
Video Input 16 Cams
Audio Input 16 Channels
Recording Rate (D1) NTSC 480 fps PAL 400 fps
Display Rate NTSC 480 fps PAL 400 fps
Video Resolution NTSC Hardware 704 x 480 704 x 480
Software 352 x 240 352 x 240
PAL Hardware 704 x 576 704 x 576
Software 352 x 288 352 x 288
Video Compression Software Geo MPEG4, Geo H264
Hardware H264
Audio Compression 16 kHz / 16-bit, 32 kHz / 16-bit
Bit Rate Range 5M ~ 10M
marcom
Post by marcom » Fri Aug 21, 2015 12:54 pm
Looks like the link is at www geovision com tw/english/Prod_GV5016 dot asp
[ i am not allowed to post a link yet ] ....
rangerbob
Post by rangerbob » Fri Aug 21, 2015 1:42 pm
Its been a while I am going to go with NO the card does not work with Linux. . I am not going to spend on this card to find it does not work. if anyone has one and gets it to work plz correct me/us!
Users browsing this forum: No registered users and 8 guests
