Has anyone compied the techwell drivers on ubuntu 14.04 lts?
kingofkya
Post by kingofkya » Sun Apr 05, 2015 2:55 am
I cant seam to get it to work, this driver used to be super simple to compile:(
And its seams the gitorious site is haveing issues not sure if that is still the right place to get the drivers:
gitorious.org/tw68/
Anyway i made a copy In case anyone needs it / the site goes away.
kneale.us/tw68-tw68-v2.tar.gz
68-tw68-v2# make
make -C /lib/modules/3.16.0-30-generic/build M=/home/travis/tw68-tw68-v2 modules
make[1]: Entering directory `/usr/src/linux-headers-3.16.0-30-generic'
  CC [M]  /home/travis/tw68-tw68-v2/tw68-core.o
In file included from /home/travis/tw68-tw68-v2/tw68-core.c:43:0:
/home/travis/tw68-tw68-v2/tw68.h:512:43: error: expected â=â, â,â, â;â, âasmâ or â__attribute__â before âtw68_pci_tblâ
 extern struct pci_device_id __devinitdata tw68_pci_tbl[];
/home/travis/tw68-tw68-v2/tw68-core.c:514:23: error: expected â=â, â,â, â;â, âasmâ or â__attribute__â before âmust_configure_manuallyâ
 static void __devinit must_configure_manually(void)
/home/travis/tw68-tw68-v2/tw68-core.c: In function âvdev_initâ:
/home/travis/tw68-tw68-v2/tw68-core.c:591:5: error: âstruct video_deviceâ has no member named âparentâ
  vfd->parent  = &dev->pci->dev;
/home/travis/tw68-tw68-v2/tw68-core.c: At top level:
/home/travis/tw68-tw68-v2/tw68-core.c:654:22: error: expected â=â, â,â, â;â, âasmâ or â__attribute__â before âtw68_initdevâ
 static int __devinit tw68_initdev(struct pci_dev *pci_dev,
/home/travis/tw68-tw68-v2/tw68-core.c:910:23: error: expected â=â, â,â, â;â, âasmâ or â__attribute__â before âtw68_finidevâ
 static void __devexit tw68_finidev(struct pci_dev *pci_dev)
/home/travis/tw68-tw68-v2/tw68-core.c:1058:14: error: âtw68_pci_tblâ undeclared here (not in a function)
  .id_table = tw68_pci_tbl,
/home/travis/tw68-tw68-v2/tw68-core.c:1059:13: error: âtw68_initdevâ undeclared here (not in a function)
  .probe   = tw68_initdev,
/home/travis/tw68-tw68-v2/tw68-core.c:1060:2: error: implicit declaration of function â__devexit_pâ [-Werror=implicit-function-declaration]
  .remove   = __devexit_p(tw68_finidev),
/home/travis/tw68-tw68-v2/tw68-core.c:1060:26: error: âtw68_finidevâ undeclared here (not in a function)
/home/travis/tw68-tw68-v2/tw68-core.c:93:21: warning: âtw68_devcountâ defined but not used [-Wunused-variable]
 static unsigned int tw68_devcount;      /* curr tot num of devices present */
/home/travis/tw68-tw68-v2/tw68-core.c:368:12: warning: âtw68_hw_init1â defined but not used [-Wunused-function]
 static int tw68_hw_init1(struct tw68_dev *dev)
/home/travis/tw68-tw68-v2/tw68-core.c:491:12: warning: âtw68_hw_init2â defined but not used [-Wunused-function]
 static int tw68_hw_init2(struct tw68_dev *dev)
/home/travis/tw68-tw68-v2/tw68-core.c:503:12: warning: âtw68_hwfiniâ defined but not used [-Wunused-function]
 static int tw68_hwfini(struct tw68_dev *dev)
/home/travis/tw68-tw68-v2/tw68-core.c:542:20: warning: âtw68_irqâ defined but not used [-Wunused-function]
 static irqreturn_t tw68_irq(int irq, void *dev_id)
/home/travis/tw68-tw68-v2/tw68-core.c:579:29: warning: âvdev_initâ defined but not used [-Wunused-function]
 static struct video_device *vdev_init(struct tw68_dev *dev,
/home/travis/tw68-tw68-v2/tw68-core.c:599:13: warning: âtw68_unregister_videoâ defined but not used [-Wunused-function]
 static void tw68_unregister_video(struct tw68_dev *dev)
/home/travis/tw68-tw68-v2/tw68-core.c:626:13: warning: âmpeg_ops_attachâ defined but not used [-Wunused-function]
 static void mpeg_ops_attach(struct tw68_mpeg_ops *ops,
/home/travis/tw68-tw68-v2/tw68-core.c:642:13: warning: âmpeg_ops_detachâ defined but not used [-Wunused-function]
 static void mpeg_ops_detach(struct tw68_mpeg_ops *ops,
cc1: some warnings being treated as errors
make[2]: *** [/home/travis/tw68-tw68-v2/tw68-core.o] Error 1
make[1]: *** [_module_/home/travis/tw68-tw68-v2] Error 2
make[1]: Leaving directory `/usr/src/linux-headers-3.16.0-30-generic'
make: *** [all] Error 2
asker
Re: Has anyone compied the techwell drivers on ubuntu 14.04
Post by asker » Mon Apr 06, 2015 5:28 pm
I have zero idea but I took a look anyway ;-)
a) The code uses __dev* initializers - they are no longer used in later linux kernels
To fix it, add this to tw68.h right at the top
#define __devinit
#define __devinitdata
#define __devexit
#define __devexitdata
#define __devexit_p
b) Next up, certain structures have changed in newer library versions.
Edit tw68-core.c:line 591, change "parent" to "dev_parent" (that's the new name)
 vfd->dev_parent  = &dev->pci->dev;
c) Finally, edit tw68-video.c: line 2079
comment out .current_norm --> that field does not exist anymore in V4L
now make and it will compile.
Whether it works or not, I haven't a clue :-)
