So did some tests and to get it to work with IE 10 you need the following changes diff was against 1.25 version
Summary is that you need to use the object class instead of applet since IE 10 does not like it unsigned in the function outputHelperStream()
Then add new definition for IE 11 in function getBrowser()
Modify the MSIE detection so it catches IE 10 as well as older ones in function getBrowser().
393,402c393,401
< <object
< classid="clsid:8AD9C840-044E-11D1-B3E9-00805F499D93"
< width="<?= $width ?>"
< height="<?= $height ?>"
< title="<?= $title ?>">
< <param name="code" value="com.charliemouse.cambozola.Viewer">
< <param name="archive" value="<?= ZM_PATH_CAMBOZOLA ?>">
< <param name="accessories" value="none"/>
< <param name="url" value="<?= $src ?>"/>
< </object>
> <applet id="<?= $id ?>" code="com.charliemouse.cambozola.Viewer"
> archive="<?= ZM_PATH_CAMBOZOLA ?>"
> align="middle"
> </applet>
792,797c791
< if ( preg_match( '/Trident\/7.0; rv:11.0/', $_SERVER['HTTP_USER_AGENT'], $logVersion) )
< $version = $logVersion[1];
< $browser = 'ie';
< elseif ( preg_match( '/MSIE (.*?);/', $_SERVER['HTTP_USER_AGENT'], $logVersion) )
> if ( preg_match( '/MSIE ([0-9].[0-9]{1,2})/', $_SERVER['HTTP_USER_AGENT'], $logVersion) )
cheers
