ffmpeg replaced by avconv? (debian)
PacoLM
Post by PacoLM » Thu Apr 19, 2012 5:48 am
I'm doing some tests installing ZM 1.25 in ARM based devices. After finishing the installation and setup, when creating a video of an event it fails (I'm working on fixing this), the ffmpeg.log shows this advice:
ffmpeg version 0.8.1-5:0.8.1-4, Copyright (c) 2000-2011 the Libav developers
  built on Mar 30 2012 23:32:38 with gcc 4.6.2
*** THIS PROGRAM IS DEPRECATED ***
This program is only provided for compatibility and will be removed in a future release. Please use avconv instead.
Is ZM going to support avconv and/or ffmpeg?.
Regards,
PacoLM
mini-ITX system (6 IPCams - Ubuntu14.04 - ZM1.31.1)
nightcrawler
Re: ffmpeg replaced by avconv? (debian)
Post by nightcrawler » Thu Apr 19, 2012 8:21 am
paco,
it already supports FFMPEG.... (just install the ffmpeg libs and set the use ffmpeg option at zm)
Zoneminder @Ubuntu 11 server, ZM 1.25.0 , FFMPEG, 4 Analoge cameras, 1.6ghz P4mobile, 2GB ram, 60GB-HDD.
I also have an (homeseer) domotica system up-and-running with touchscreens,light controllers,weather forecast etc.
PacoLM
Post by PacoLM » Thu Apr 19, 2012 12:18 pm
Yes, I know that ZM supports ffmpeg, but ffmpeg is going to be deprecated, as the message says. My question was if zoneminder is going to migrate from ffmepg to avconv.
mitch
Post by mitch » Thu Apr 19, 2012 2:10 pm
they just are breaking the old command line compat avconv is just the most likely new name for the command line but ffmpeg command line will still be around for awhile. More details see:
http://ffmpeg.org/pipermail/ffmpeg-deve ... 13869.html
cambot
Post by cambot » Tue Apr 24, 2012 9:20 pm
I hope that Zoneminder will have the option of using original ffmpeg like it does currently. I just finished figuring out that my Axis M3114 camera is not compatible with the latest libav (avconv), and that I needed to install the most recent ffmpeg to get it to work.
dma_k
Post by dma_k » Mon Nov 24, 2014 11:32 pm
cambot wrote:I hope that Zoneminder will have the option of using original ffmpeg like it does currently.
And that makes a lot of sense, as ffmeg is back (at least to Ubuntu).
