Zoneminder install DVD 1.24.x (3/7/2011)
Got the cards working, but still have a minor issue- ZM doesn't seem to save the montage layout view. Whichever view I last selected is still shown, but the layout itself goes back to a single column until I change the view to something different.
Also noticed that most of the monitors take a long time to become available, which is why I thought I was having BTTV issues at first. Not sure if the computer is too slow, or that it's acting up because I only have one input supplied with a signal. Sometimes I can make them become available (turn from red to orange) by opening the properties on them and saving them again.
Making good progress though. I might try this distro on my main ZM system in a bit.
Re: Zoneminder install DVD 1.24.x download
I tried to install from this DVD choosing the direct install in the boot menu.newvisionantenna wrote:update 9/28/2010
updated install dvd with ubuntu desktop - appears to correct desktop login and install procedure.
http://newvisionantenna.com/br541/awd-z ... 10-rc1.iso
http://newvisionantenna.com/br541/awd-z ... c1.iso.md5
But it looks like it just booted live and no installation took place.
The HD already have Windows XP. Should I repartition it first?
Einar AT_CHARACTER eunet DOT_CHARACTER no
- Contact:
It's great to see this dvd is still getting use. I'm not sure what may have happened during your install. From what I remember you may have to go into live mode and then select the install from either the desktop or under one of the menu options.
I can't believe it's almost two years since I joined this forum. A lot has happened in this time. I found zoneminder why trying to make a "wireless mesh" security system. At one point I had wireless routers running webcams and reporting into zoneminder and all kinds of stuff lying around my house. Eventually I had to turn focus on other things, but I'm very thankful for sticking to what I had ideas about.
If anyone is interested in looking at the end result of a lot of hard-work and ideas just take a look here.
http://www.awdmesh.com
I can't support it officially on the site, but if anyone wants to get with me offline I can talk about how one of the products can run usb webcams and link into zoneminder.
Just a few quick questions:
When the initial prompt appears to install, is something supposed to happen other than just be take to the Live DVD environment with option to install zoneminder on the desktop?
Also when I click that and install, Zoneminder is not installed, is this correct?
Cheers
Ignore me: I see what is going on now
Cheers
I get the same thing- have tried DL again and reburning disk but all I get is the boot menu and then it freezes instead of installing.eddiex wrote:So... how does this work?
I have dl the ISO files, and boot on it.. on vmware...
I gets the boot menu...
But when I select something (execpt memory check) it freeze.
(memory check works)..
Any ideas?
Eddie
Any suggestions anyone?
I must be missing something
I have everything installed and running in a vm for testing, but I can't access the zoneminder web interface, I dont seem to know what the user name and password are, is the some kind of default password I need to put in? or a script I need to run? anyhelp would be appreciated.
Joe
Joe
- Contact:
Just a small question, i have tried the DVD Iso from the first post and all works well
Just one question, i need to install some software on the machine after installing it, but do not have the password for root
And when i SU or SUDO no password i try works.
Can someone send me the default (direct install) root/SU password?
Same here.cooj wrote:I get the same thing- have tried DL again and reburning disk but all I get is the boot menu and then it freezes instead of installing.eddiex wrote:So... how does this work?
Any ideas?
Eddie
It looks like this version works only with 64bit processors.
Any link with older versions?
For me, i had the same issues with freezing at first as well(i would select a menu item, then it it would to load and then stop), so i changed from an old dvd burner to a new DVD burner, and it started to work, and has since installed it several times using the new burnercooj wrote:I get the same thing- have tried DL again and reburning disk but all I get is the boot menu and then it freezes instead of installing.eddiex wrote:So... how does this work?
Any ideas?
Eddie
nevermind i found that there is no default password for SU/SUDO.Source wrote:Just a small question, i have tried the DVD Iso from the first post and all works well
just going to a terminal and typing:
sudo passwd
enter your current user password
then enter twice a new root/su/sudo password, and all was happy.
- Contact:
