Reason why you shouldnt use cameras with built in IR emitter
That's a thought Moth Balls .
I bought a can of Konk bug /fly killer. And sprayed . It keeps the spiders at bay for a couple of weeks, except for one cam mounted near the aliminum power entrance pipe. I call those JC Vandam spiders cuz they are Hard to Kill.
I'm on a Dairy farm so the bugs are going to be bad no matter what I do.
And the cat's turning on the yard light makes lots of footage as well.
If anyone knows of a site with kits or plans for IR illumination please post a link. I'd build one to try.
Allan
Allan
If you find yourself a brighter IR source, I'd still consider putting one nearby the camera attached to a bug zapper. Presumably they'd go for the brighter source, but I'm not an entomologist.
If you have a spare small compressor laying about somewhere, you could also possibly rig it to blast the lens with air every so often.
or just use seperate cams and emitters like we used to lol
James Wilson
Good Bullet IRs
Lee Sharp:
What type of integrated ir/bullet camera's do you have experience with? Do you recommend them for commercial use or residential?
We buy them in bulk direct from Asia. I have many installed in commercial locations, (including some on the beach... Salt sucks) and a few residential. But you also have to consider location. I have yet to see a spyder or moth problem here in Houston, but I have seen more than a few pictures.
PM me if you want more detail.
