ffmpeg (15660) is complied using --enable-swscale --enable-gpl --enable-shared.
Zoneminder 1.24 2678 is complied using --with-webdir=/var/www/zm/ --with-cgidir=/usr/lib/cgi-bin/ --with-webuser=www-data --with-webgroup=www-data ZM_DB_NAME=zm ZM_DB_USER=zmuser ZM_DB_PASS=zmpass --enable-nmap
(Have also tired --with-ffmpeg=/usr/local/bin/ or --with-ffmpeg=/usr/local and I've also tired without --enable-nmap).
I'm also using the SIMD jpeg library.
When I try to view the streams from the camera nothing happens, error.log reports "Timeout waiting for output from CGI script /usr/lib/cgi-bin/zms".
Looking at the debug logs in /tmp/ I find this towards the end (the whole file contains over 6500 lines so I don't really want to post it all but will post more if required).
I've noticed this line:
I'm not sure if this is a red hearing but could this be my problem (and responsible backtrace of libc.so.6)?10/30/08 14:25:46.118997 zmc_m1[4903].FAT-zm_remote_camera_rtsp.cpp/150 [Unable to locate codec 0 decoder]
Here's a few lines before and the rest of the debug log:
any help appreciated!10/30/08 14:25:46.081681 zmc_m1[4905].DB4-zm_rtp_data.cpp/97 [Got 1472 bytes on sd 6]
10/30/08 14:25:46.081711 zmc_m1[4905].DB5-zm_rtp_data.cpp/44 [Ver: 2]
10/30/08 14:25:46.081731 zmc_m1[4905].DB5-zm_rtp_data.cpp/45 [P: 0]
10/30/08 14:25:46.081751 zmc_m1[4905].DB5-zm_rtp_data.cpp/46 [Pt: 96]
10/30/08 14:25:46.081771 zmc_m1[4905].DB5-zm_rtp_data.cpp/47 [Mk: 0]
10/30/08 14:25:46.081792 zmc_m1[4905].DB5-zm_rtp_data.cpp/48 [Seq: 29785]
10/30/08 14:25:46.081812 zmc_m1[4905].DB5-zm_rtp_data.cpp/49 [T/S: 4e7f46b2]
10/30/08 14:25:46.081832 zmc_m1[4905].DB5-zm_rtp_data.cpp/50 [SSRC: 21d8339e]
10/30/08 14:25:46.081852 zmc_m1[4905].DB5-zm_rtp_source.cpp/87 [Seq: 29785]
10/30/08 14:25:46.081872 zmc_m1[4905].DB3-zm_rtp_source.cpp/117 [Packet in sequence, gap 1]
10/30/08 14:25:46.081892 zmc_m1[4905].DB4-zm_rtp_source.cpp/259 [16: bd 31 1c ce af 14 4b 6a 33 73 8a 17 a8 4f a6 20]
10/30/08 14:25:46.081949 zmc_m1[4905].DB4-zm_rtp_source.cpp/262 [16: 00 00 01 b0 03 00 00 01 b5 09 00 00 01 00 00 00]
10/30/08 14:25:46.081975 zmc_m1[4905].DB5-zm_rtp_source.cpp/187 [RTP Jitter: 0]
10/30/08 14:25:46.082001 zmc_m1[4905].DB4-zm_rtp_data.cpp/97 [Got 1472 bytes on sd 6]
10/30/08 14:25:46.082022 zmc_m1[4905].DB5-zm_rtp_data.cpp/44 [Ver: 2]
10/30/08 14:25:46.082042 zmc_m1[4905].DB5-zm_rtp_data.cpp/45 [P: 0]
10/30/08 14:25:46.082062 zmc_m1[4905].DB5-zm_rtp_data.cpp/46 [Pt: 96]
10/30/08 14:25:46.082082 zmc_m1[4905].DB5-zm_rtp_data.cpp/47 [Mk: 0]
10/30/08 14:25:46.082102 zmc_m1[4905].DB5-zm_rtp_data.cpp/48 [Seq: 29786]
10/30/08 14:25:46.082122 zmc_m1[4905].DB5-zm_rtp_data.cpp/49 [T/S: 4e7f46b2]
10/30/08 14:25:46.082142 zmc_m1[4905].DB5-zm_rtp_data.cpp/50 [SSRC: 21d8339e]
10/30/08 14:25:46.082163 zmc_m1[4905].DB5-zm_rtp_source.cpp/87 [Seq: 29786]
10/30/08 14:25:46.082183 zmc_m1[4905].DB3-zm_rtp_source.cpp/117 [Packet in sequence, gap 1]
10/30/08 14:25:46.082203 zmc_m1[4905].DB4-zm_rtp_source.cpp/259 [16: 24 4f 45 52 65 0b a3 da 37 d3 72 a0 86 b8 8e d2]
10/30/08 14:25:46.082272 zmc_m1[4905].DB4-zm_rtp_source.cpp/262 [16: 00 00 01 b0 03 00 00 01 b5 09 00 00 01 00 00 00]
10/30/08 14:25:46.082299 zmc_m1[4905].DB5-zm_rtp_source.cpp/187 [RTP Jitter: 0]
10/30/08 14:25:46.082324 zmc_m1[4905].DB4-zm_rtp_data.cpp/97 [Got 1472 bytes on sd 6]
10/30/08 14:25:46.082345 zmc_m1[4905].DB5-zm_rtp_data.cpp/44 [Ver: 2]
10/30/08 14:25:46.082365 zmc_m1[4905].DB5-zm_rtp_data.cpp/45 [P: 0]
10/30/08 14:25:46.082385 zmc_m1[4905].DB5-zm_rtp_data.cpp/46 [Pt: 96]
10/30/08 14:25:46.082405 zmc_m1[4905].DB5-zm_rtp_data.cpp/47 [Mk: 0]
10/30/08 14:25:46.082425 zmc_m1[4905].DB5-zm_rtp_data.cpp/48 [Seq: 29787]
10/30/08 14:25:46.082445 zmc_m1[4905].DB5-zm_rtp_data.cpp/49 [T/S: 4e7f46b2]
10/30/08 14:25:46.082465 zmc_m1[4905].DB5-zm_rtp_data.cpp/50 [SSRC: 21d8339e]
10/30/08 14:25:46.082486 zmc_m1[4905].DB5-zm_rtp_source.cpp/87 [Seq: 29787]
10/30/08 14:25:46.082506 zmc_m1[4905].DB3-zm_rtp_source.cpp/117 [Packet in sequence, gap 1]
10/30/08 14:25:46.082526 zmc_m1[4905].DB4-zm_rtp_source.cpp/259 [16: 42 57 17 12 99 4a 5e c0 e4 7a 9b 12 7e 37 78 d4]
10/30/08 14:25:46.082584 zmc_m1[4905].DB4-zm_rtp_source.cpp/262 [16: 00 00 01 b0 03 00 00 01 b5 09 00 00 01 00 00 00]
10/30/08 14:25:46.082610 zmc_m1[4905].DB5-zm_rtp_source.cpp/187 [RTP Jitter: 0]
10/30/08 14:25:46.082635 zmc_m1[4905].DB4-zm_rtp_data.cpp/97 [Got 319 bytes on sd 6]
10/30/08 14:25:46.082656 zmc_m1[4905].DB5-zm_rtp_data.cpp/44 [Ver: 2]
10/30/08 14:25:46.082676 zmc_m1[4905].DB5-zm_rtp_data.cpp/45 [P: 0]
10/30/08 14:25:46.082696 zmc_m1[4905].DB5-zm_rtp_data.cpp/46 [Pt: 96]
10/30/08 14:25:46.082716 zmc_m1[4905].DB5-zm_rtp_data.cpp/47 [Mk: 1]
10/30/08 14:25:46.082736 zmc_m1[4905].DB5-zm_rtp_data.cpp/48 [Seq: 29788]
10/30/08 14:25:46.082756 zmc_m1[4905].DB5-zm_rtp_data.cpp/49 [T/S: 4e7f46b2]
10/30/08 14:25:46.082776 zmc_m1[4905].DB5-zm_rtp_data.cpp/50 [SSRC: 21d8339e]
10/30/08 14:25:46.082796 zmc_m1[4905].DB5-zm_rtp_source.cpp/87 [Seq: 29788]
10/30/08 14:25:46.082816 zmc_m1[4905].DB3-zm_rtp_source.cpp/117 [Packet in sequence, gap 1]
10/30/08 14:25:46.082836 zmc_m1[4905].DB4-zm_rtp_source.cpp/259 [16: 65 40 3a 0c 20 c1 6e 9d 54 7b a5 45 91 79 f1 b8]
10/30/08 14:25:46.082870 zmc_m1[4905].DB4-zm_rtp_source.cpp/262 [16: 00 00 01 b0 03 00 00 01 b5 09 00 00 01 00 00 00]
10/30/08 14:25:46.082896 zmc_m1[4905].DB2-zm_rtp_source.cpp/268 [Got new frame 0, 99587 bytes]
10/30/08 14:25:46.082917 zmc_m1[4905].DB8-zm_thread.cpp/215 [Updating value with signal, 0xf63d8ac]
10/30/08 14:25:46.082940 zmc_m1[4905].DB9-zm_thread.cpp/221 [Updated value, 0xf63d8ac]
10/30/08 14:25:46.082962 zmc_m1[4905].DB8-zm_thread.cpp/201 [Waiting for value update, 1 secs, 0xf63d8fc]
10/30/08 14:25:46.082983 zmc_m1[4905].DB8-zm_thread.cpp/127 [Waiting for 1 seconds]
10/30/08 14:25:46.118951 zmc_m1[4903].DB2-zm_remote_camera_rtsp.cpp/129 [Got sources]
10/30/08 14:25:46.119113 zmc_m1[4903].INF-zm_signal.cpp/60 [Got signal 6 (Aborted), crashing]
10/30/08 14:25:46.119153 zmc_m1[4903].ERR-zm_signal.cpp/71 [Signal address is (nil), from 0xb7fbf410]
10/30/08 14:25:46.119408 zmc_m1[4903].ERR-zm_signal.cpp/98 [Backtrace: [0xb7fbf410]]
10/30/08 14:25:46.119442 zmc_m1[4903].ERR-zm_signal.cpp/98 [Backtrace: [0xb7fbf410]]
10/30/08 14:25:46.119471 zmc_m1[4903].ERR-zm_signal.cpp/98 [Backtrace: /lib/tls/i686/cmov/libc.so.6(gsignal+0x55) [0xb759f085]]
10/30/08 14:25:46.119500 zmc_m1[4903].ERR-zm_signal.cpp/98 [Backtrace: /lib/tls/i686/cmov/libc.so.6(abort+0x101) [0xb75a0a01]]
10/30/08 14:25:46.119529 zmc_m1[4903].ERR-zm_signal.cpp/98 [Backtrace: /usr/local/bin/zmc [0x8055367]]
10/30/08 14:25:46.119557 zmc_m1[4903].ERR-zm_signal.cpp/98 [Backtrace: /usr/local/bin/zmc [0x807b942]]
10/30/08 14:25:46.119586 zmc_m1[4903].ERR-zm_signal.cpp/98 [Backtrace: /usr/local/bin/zmc [0x804d1f8]]
10/30/08 14:25:46.119615 zmc_m1[4903].ERR-zm_signal.cpp/98 [Backtrace: /lib/tls/i686/cmov/libc.so.6(__libc_start_main+0xe0) [0xb758a450]]
10/30/08 14:25:46.119644 zmc_m1[4903].ERR-zm_signal.cpp/98 [Backtrace: /usr/local/bin/zmc(__gxx_personality_v0+0x3a5) [0x804cca1]]
10/30/08 14:25:46.119854 zmc_m1[4903].INF-zm_signal.cpp/99 [Backtrace complete]
