Wanting to embed just the video stream on other Site
Ricardol
Post by Ricardol »
Hello. I am running zoneminder 1.22 on kubuntu 7.10 and i have a question. I would like to take just the video stream from one monitor and embed it on another web site. i read in the forums that i could take the url from the jpeg image that shows in the monitor page from zoneminder console and use that. But when i load that url in a blank firegox or explorer page, i get just the first frame of the stream, and the frame wont refresh. Can somoene tell me what could be the problem?
Ricardo
zoneminder
Site Admin
Post by zoneminder »
You might not need just the url, but also the enclosing embed or object tags.
Phil
Ricardol
Post by Ricardol »
Could you explain that idea to me a little more?
zoneminder
Site Admin
If you are just viewing an mjpeg stream then you just need something like
<img src="http://<yourip>/cgi-bin/nph-zms?mode=jpeg&monitor=1&scale=100&maxfps=2&auth=beabc4e2e6aa50f15f910e844" alt="Front" border="0" width="352" height="288">
with the url inside an img tag, but if you were wanting to stream an mpeg feed then you would need this
<embed type="video/x-ms-asf"
src="http://<yourip>/cgi-bin/nph-zms?mode=mpeg&monitor=1&scale=100&bitrate=25000&maxfps=2&format=asf&auth=b569dd73a50f15f910e8446"
width="352"
height="288"
name="Front"
autostart="1"
autoplay="1"
showcontrols="0"
controller="0">
</embed>
and so on. Likewise the url you present to IE for mjpeg streaming might need to wrap the url in references to the cambozola applet.
So basically just having the url to the zms feed is not enough, it needs to be wrapped in appropriate html to display the content type for the relevant browser.
Phil
azir
Post by azir »
I use this script for my similiar case.
place the script zm_img.php to the web root directory of zoneminder
(mine is /var/www/htdocs/zm)
please add opening an closing php tag yourself, i got problem with formatting here
seem like i need to familiarize myself with bbcode
:D
** zm_img.php
import_request_variables( "CGP" );
// Use new style autoglobals where possible
if ( version_compare( phpversion(), "4.1.0", "<") )
  	$_SESSION = &$HTTP_SESSION_VARS;
  	$_SERVER = &$HTTP_SERVER_VARS;
if ( $_SERVER['REMOTE_ADDR'] != 'xxx.xxx.xxx.xxx' ) {
    exit();
if ( !isset($PHP_SELF) )
	$PHP_SELF = $_SERVER['PHP_SELF'];
if ( isset($_SERVER["HTTPS"]) && $_SERVER["HTTPS"] == 'on' )
	$protocol = 'https';
else
	$protocol = 'http';
if(!isset($bandwidth))
    $bandwidth  = "low";
define( "ZM_BASE_URL", $protocol.'://'.$_SERVER['HTTP_HOST'] );
ini_set( "session.name", "ZMSESSID" );
ini_set( "session.use_cookies", "0" );
ini_set( "session.use_trans_sid", "1" );
session_start();
require_once "zm_config.php";
require_once "zm_funcs.php";
userLogin('foo', 'bar');
if(isset($_GET['mid'])) {
    $mid = $_GET['mid'];
else {
    $mid = 1;
$scale = 100;
$streamarg = array( "mode=jpeg",
                    "monitor=".$mid,
                    "scale=".$scale,
                    "maxfps=".ZM_WEB_VIDEO_MAXFPS );
$stream_src = getStreamSrc( $streamarg );
$stream_src = str_replace("&", "&", $stream_src);
header("Location: $stream_src&ZMSESSID=".session_id());
exit();
My zm running in built in authentication mode, I created user foo with password bar for the script above, fix with yours
If your zm is not running in authenticated mode, comment the userLogin(... line.
Here is an example page shows how to use it
<html>
<head><title>ZM image</title></head>
<body>
<monitor>
<img src='http://yyy.yyy.yyy.yyy/zm/zm_img.php?mid=1" />
<br>
<monitor>
<img src='http://yyy.yyy.yyy.yyy/zm/zm_img.php?mid=2" />
</body>
</html>
note:
xxx.xxx.xxx.xxx : ip address of remote viewer page / hosting (the other Site)
yyy.yyy.yyy.yyy : ip address or FQDN of box where zm installed
Hope that helps
Ricardol
Post by Ricardol »
Thank you very much for all your help. I will try this ideas and post results.
Ricardo
