Hi
Thaks for this forum i think its incredible
I've bought some cameras IMOU and i want to use zoneminde on a PC like a recorder
The problems is that i can`t obtain the live image.
I can`t connect to the cameras
I`ve trie a lot of configuration thaht i found on this forum and in other places and I can't get it
I've set static IP.
I've used this config with this path:
rtsp://admin:SAFTEY_CODE@192.168.XX.XX:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
Atached the config
Can anyone help me? What i am doing wrong?
Imou cameras
Imou cameras
- Captura.JPG (32.34 KiB) Viewed 10650 times
Re: Imou cameras
See: https://wiki.zoneminder.com/Finding_Camera_Stream_Paths
It's easier to troubleshoot with ffprobe or ffmpeg.
e.g. try from the terminal:
A web search online comes up with:
https://ipcamtalk.com/threads/imou-rang ... ved.60271/
https://www.ispyconnect.com/camera/imou
https://ipcamtalk.com/threads/imou-rang ... vif.42605/
What model of imou do you have?
ffprobe rtsp://admin:SAFTEY_CODE@192.168.XX.XX:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
fastest way to test streams:
Re: Imou cameras
First of all tahnks for your fast reply
I've two models, one is a Cruiser dual and the other one it's a Cell 3
I'm completly new in this world so thanks for the info.
I'am doind some test and i'll update the post
thanks
thanks
Re: Imou cameras
I've been doing some tests with the cruiser dual
I'cant view the image and contor it with ODM program
But i cant get it with zoneminder
The rtsp that i can view on ODM is:
rtsp://192.168.5.xx:554/cam/realmonitor?channel=2&subtype=0&unicast=true&proto=Onvif
But with zoneminder i cant
i've tried too on VLC and i can hear the sound but i can watch the video
Re: Imou cameras
Good Morning
I've advanced with this config and now i have the camera on ZeoneMinder
I've used the config of Dahua (wich it looks to be the manufacturer of IMOU cameras too)
https://wiki.zoneminder.com/Dahua
Config Tab Option Config Setting
General Source Type Ffmpeg
Source Source Path rtsp://admin:password@192.168.0.xxx:554/cam/realmonitor?channel=1&subtype=0&unicast=true&proto=Onvif
Remote Method UDP
Target Colorspace 32 bit colour
Capture Width (pixels) 1920
Capture Height (pixels) 1080
Preserve Aspect Ratio Unselected
Orientation Normal
Deinterlacing Disabled
Remote Method UDP
Orientation Normal
