I have ZM setup with notifications pushed through to pushover but running into an issue where when multiple notifications are stacked in a short time, the photo becomes partially blocked.
The issue became apparent since I have two cameras with overlapping trigger zones, so when two cameras trigger an alarm, both notifications are sent out with either one or both photos being blocked.
Is there any way to fix the photos being sent, or maybe delay the notifications a few seconds apart?
There's no issue when notifications are separated in time, but even if the same camera triggers multiple times in a short time, it does the same thing.
Running ZM v1.36.33
Camera 1 sub stream in mocord, main stream in nodect linked to sub stream
Camera 2 sub stream in mocord, main stream in nodect linked to sub stream
zmeventnotification.ini file is still in default mode for pictures from what I can tell
# BESTMATCH should be used only if you are using bestmatch for FID in detect_wrapper.sh
# objdetect is ONLY available in ZM 1.33+
# objdetect_mp4 and objdetect_gif is ONLY available
# in ZM 1.35+
picture_url = !ZMES_PICTURE_URL
picture_portal_username=!ZM_USER
picture_portal_password=!ZM_PASSWORD
