The Ubuntu 20.04 package (I haven't reviewed others) does not seem to include the systemd tmpfiles config that in previous versions was located at /ust/lib/tmpfiles.d/zoneminder.conf
This means required files in /run are not created on boot.
I have also lodged this as an issue on Github as this looks like a bug to me: https://github.com/ZoneMinder/zoneminder/issues/3258
Version 1.36 on Ubuntu does not include systemd tmpfiles.d
Re: Version 1.36 on Ubuntu does not include systemd tmpfiles.d
I'm not sure this is actually true. I suspect it is some issue with your system.
apt-file zoneminder shows it listed for me.
Also I think we would be hearing more complaints.
I’ve tried an install on an Ununtu 20.04 container multiple times and a completely new VM today with the same results.
I’m a bit confused too to be honest as I’m sure you are correct that this would be causing a bunch of reports so I’d love to know under what situation the file is not installed.
Here is some output from my testing today:
user@TEST-UBN01:~$ dpkg --listfiles zoneminder | grep tmpfiles
user@TEST-UBN01:~$ ls -l /usr/lib/tmpfiles.d/
total 76
-rw-r--r-- 1 root root 465 Feb 11 2020 00rsyslog.conf
-rw-r--r-- 1 root root 35 Sep 17 2020 cryptsetup.conf
-rw-r--r-- 1 root root 365 Jun 12 2020 dbus.conf
-rw-r--r-- 1 root root 517 Mar 18 04:50 debian.conf
-rw-r--r-- 1 root root 362 Apr 2 2020 home.conf
-rw-r--r-- 1 root root 1096 Apr 2 2020 journal-nocow.conf
-rw-r--r-- 1 root root 812 Mar 18 05:36 legacy.conf
-rw-r--r-- 1 root root 61 Feb 14 2020 lvm2.conf
-rw-r--r-- 1 root root 33 Feb 26 2020 man-db.conf
-rw-r--r-- 1 root root 239 Feb 7 2020 passwd.conf
-rw-r--r-- 1 root root 29 Jun 19 2017 screen-cleanup.conf
-rw-r--r-- 1 root root 697 Mar 18 05:36 static-nodes-permissions.conf
-rw-r--r-- 1 root root 305 Jan 19 22:21 sudo.conf
-rw-r--r-- 1 root root 597 Apr 2 2020 systemd-nologin.conf
-rw-r--r-- 1 root root 823 Apr 2 2020 systemd-tmp.conf
-rw-r--r-- 1 root root 1792 Mar 18 05:36 systemd.conf
-rw-r--r-- 1 root root 448 Mar 18 05:36 tmp.conf
-rw-r--r-- 1 root root 568 Mar 18 05:36 var.conf
-rw-r--r-- 1 root root 655 Apr 2 2020 x11.conf
rgroup@RGI-TST-UBN01:~$ apt info zoneminder
Package: zoneminder
Version: 1.36.2-focal1
Priority: optional
Section: net
Maintainer: Isaac Connor <isaac@zoneminder.com>
Installed-Size: 37.0 MB
Depends: libavcodec58 (>= 7:4.2), libavformat58 (>= 7:4.2), libavutil56 (>= 7:4.0), libc6 (>= 2.27), libgcc-s1 (>= 3.0), libgcrypt20 (>= 1.8.0), libgnutls30 (>= 3.6.5), libjpeg8 (>= 8c), libjwt-gnutls0 (>= 1.9.0), libmysqlclient21 (>= 8.0.11), libpcre3, libstdc++6 (>= 6), libswresample3 (>= 7:4.0), libswscale5 (>= 7:4.0), zlib1g (>= 1:1.1.4), perl:any, javascript-common, ffmpeg, libdate-manip-perl, libmime-lite-perl, libmime-tools-perl, libdbd-mysql-perl, libphp-serialization-perl, libmodule-load-conditional-perl, libnet-sftp-foreign-perl, libarchive-zip-perl, libdevice-serialport-perl, libimage-info-perl, libjson-maybexs-perl, libsys-mmap-perl, liburi-encode-perl, libwww-perl, liburi-perl, libdata-dump-perl, libdatetime-perl, libclass-std-fast-perl, libsoap-wsdl-perl, libio-socket-multicast-perl, libdigest-sha-perl, libsys-cpu-perl, libsys-meminfo-perl, libdata-uuid-perl, libnumber-bytes-human-perl, libfile-slurp-perl, default-mysql-client | mariadb-client | virtual-mysql-client, php-mysql, php-gd, php-apcu, php-apc | php-apcu-bc, php-json, policykit-1, rsyslog | system-log-daemon, zip, libcrypt-eksblowfish-perl, libdata-entropy-perl, libvncclient1 | libvncclient0
Recommends: apache2 (>= 2.4.6-4~) | nginx | httpd, libapache2-mod-php | php-fpm, default-mysql-server | mariadb-server | virtual-mysql-server, zoneminder-doc (>= 1.36.2-focal1)
Suggests: fcgiwrap, logrotate
Download-Size: 4814 kB
APT-Manual-Installed: yes
APT-Sources: http://ppa.launchpad.net/iconnor/zoneminder-1.36/ubuntu focal/main amd64 Packages
Description: video camera security and surveillance solution
ZoneMinder is intended for use in single or multi-camera video security
applications, including commercial or home CCTV, theft prevention and child
or family member or home monitoring and other care scenarios. It
supports capture, analysis, recording, and monitoring of video data coming
from one or more video or network cameras attached to a Linux system.
ZoneMinder also support web and semi-automatic control of Pan/Tilt/Zoom
cameras using a variety of protocols. It is suitable for use as a home
video security system and for commercial or professional video security
and surveillance. It can also be integrated into a home automation system
via X.10 or other protocols.
N: There is 1 additional record. Please use the '-a' switch to see it
user@TEST-UBN01:~$ uname -a
Linux TEST-UBN01 5.4.0-73-generic #82-Ubuntu SMP Wed Apr 14 17:39:42 UTC 2021 x86_64 x86_64 x86_64 GNU/Linux
Okay now I'm really confused.
apt-file show zoneminder | grep tmpfiles lists it, but you are right dpkg --listfiles zoneminder doesn't. Also dpkg --contents ./zoneminder_1.36.0-focal1_amd64.deb doesn't list it.
So I think you are definitely on to something.
bionic packages have it.
Our build files for focal and up have zoneminder.tmpfiles instead of zoneminder.tmpfile. I think the latter is what it should be.
New packages and a new release should be out by tonight.
That change in the newly released packages seems to fix that no worries.
Thanks!
Thanks!
