Bug in camera password handling
The Eye
Post by The Eye »
So I gave my cameras the user "admin" and the password "Argus5+++".
I can say, because I can't use that password anyway.
When entering this password in the ZM monitor setup, the camera could not be connected. So editing the monitor and opening the form ("Source tab") revealed:
rtsp://admin:Argu5   @<IP>/yaddayadda
Either a magic trick or URL encoding problems. Even when I manually entered the three '+++' instead of the spaces: no good.
So I have a different password now (and using rtmp:// instead of the smearing rtsp://), but I suspect someone might want to have a look at URL en/decoding in that part of ZM.
testing ZM v1.34.23 - a Turnkey Linux appliance VM running on Proxmox
VM has currently 8 Denverton Cores, 4GB RAM of which are 2.5GB shared memory, 1TB disk space
2 x Reolink RLC-410 5MP
Andyrh
Re: Bug in camera password handling
Post by Andyrh »
+ is a url command. %43 should work in the url.
Less a bug than a feature would be to have ZM translate special characters to the ASCII codes. I suspect that feature would be interesting to make work in all cases.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
