Hi everyone,
I just make everything working(took 1 day or two), im using zmeventnotification with the ML hooks.
for the past day im getting false-positive alerts.
on the false-positive alerts the image contains 'person' with 20-50% of accuracy, although on true alerts the accuracy is around 80+%
I wanna set a limit of percentage for the alerts(for example: mute 'person' alerts when accuracy < 60%).
from looking at https://zmeventnotification.readthedocs ... rules-file i can only see rules based on time of the day.
this is something can be achieved?
thanks!
eventserver - alerts based on percentage
Re: eventserver - alerts based on percentage
thanks ill try that.
Just to add, not in the rules file. Standard config file.
yeah found that, is it possible to change this percentage based on the object?
car - 30%
person - 60%
etc
car - 30%
person - 60%
etc
I don’t know. A quick look at the docs suggests ml_sequence might do it.
Short answer - No.
Longer answer - the new ml_sequence approach can do this, but in a very inefficient way and I wouldn't recommend it. But possible.
Please read before posting:
ES docs
zmNinja docs
ES docs
zmNinja docs
