[root@hostname www]# systemctl status zoneminder -l
● zoneminder.service - ZoneMinder CCTV recording and security system
Loaded: loaded (/usr/lib/systemd/system/zoneminder.service; enabled; vendor preset: disabled)
Drop-In: /usr/lib/systemd/system/zoneminder.service.d
└─zm-httpd.conf
Active: active (running) since Fri 2020-10-30 19:45:10 EDT; 31s ago
Process: 24084 ExecStop=/usr/bin/zmpkg.pl stop (code=exited, status=0/SUCCESS)
Process: 24166 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=0/SUCCESS)
Main PID: 24184 (zmdc.pl)
Tasks: 5
CGroup: /system.slice/zoneminder.service
├─24184 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
├─24224 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=1 --daemon
├─24240 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=2 --daemon
├─24250 /usr/bin/perl -wT /usr/bin/zmwatch.pl
└─24265 /usr/bin/perl -wT /usr/bin/zmstats.pl
Oct 30 19:45:26 hostname zmdc[24184]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Oct 30 19:45:40 hostname zmwatch[24250]: ERR [Memory map file '/dev/shm/zm.mmap.1' does not exist in zmMemAttach. zmc might not be running.]
Oct 30 19:45:40 hostname zmwatch[24250]: INF [Restarting capture daemon for Monitor-1, shared data not valid]
Oct 30 19:45:41 hostname zmdc[24184]: INF [Command 'zmc -m 1' removed from pending list at 20/10/30 19:45:41]
Oct 30 19:45:41 hostname zmdc[24184]: INF ['zmc -m 1' starting at 20/10/30 19:45:41, pid = 24310]
Oct 30 19:45:41 hostname zmdc[24310]: INF ['zmc -m 1' started at 20/10/30 19:45:41]
Oct 30 19:45:41 hostname zmc_m1[24310]: ERR [zmc_m1] [fopen() for ./zmc_m1.log, error = Permission denied]
Oct 30 19:45:41 hostname zmc_m1[24310]: ERR [zmc_m1] [Can't connect to server: Access denied for user 'zoneminderu'@'localhost' (using password: YES)]
Oct 30 19:45:41 hostname zmc_m1[24310]: FAT [zmc_m1] [Can't connect to db. Can't continue.]
Oct 30 19:45:41 hostname zmdc[24184]: ERR ['zmc -m 1' exited abnormally, exit status 255]
Source for the camera. FYI, there is no password on the camera yet as I am testing
rtsp://x.x.x.x:554/user=admin&password=&channel=1&stream=0.sdp
Comments / Thoughts / Suggestions
Thanks!
Gary
