Auto Stop Timeout can't be set as a decimal or fraction
Title is pretty self explanatory. I finally got ptz working on my chinese ip cam using auto onvif discovery and the netcat script, but the auto stop timeout can only be set to 0 or 1 secondplus nothing in between. Could someone help me. Am I missing something or doing something wrong? I tried to set the pan/tilt speed and step parameters to 1 but that's still not slow enough. Thanks
Re: Auto Stop Timeout can't be set as a decimal or fraction
you will need to edit /usr/share/zoneminder/www/skins/classic/views/monitor.php around line 1074
Find the html code for the Auto Stop Timeout input element
<td><input type="number" name="newMonitor[AutoStopTimeout]" value="<?php echo validHtmlStr($monitor->AutoStopTimeout()) ?>" /></td>
Change it to
<td><input type="number" name="newMonitor[AutoStopTimeout]" value="<?php echo validHtmlStr($monitor->AutoStopTimeout()) ?>" min="0" step="any"/></td>
by adding the step="any"
This fix will be in 1.34.17
Change it to
Thank you! That fixed my problem perfectly! Now my zoneminder setup is finally all good to go
Btw the decimal issue also exists when trying to setup the pan/tilt speeds in the control capability window. I hope that will be fixed as well. I'm going to try to look around the filesystem to find the right file to edit in the meantime.
Users browsing this forum: No registered users and 12 guests
