recording sound
robf355gts
recording sound
Post by robf355gts »
Hi
I'm a new user, recently installed zoneminder. 1.34.16 - great piece of software.
I previously used an old composite AVtech video system, that recorded a separate audio stream along with the video channels. Is this possible in zoneminder?
The one camera where the mic is located is video only, but I can feed the mic audio into the PC line in. Does anyone know if its possible to add in a separate monitor for audio only, or maybe specify the audio source for one of the monitor channels?
Any advice appreciated.
Regards
Rob Carter
burger
Re: recording sound
Post by burger »
I think it's a planned feature (separate audio stream), but not in 1.34. IIRC, in 1.34, video stream must have a supported audio stream in the video container. Some camera's audio are supported, and some are not. Probably Hikvision and axis are supported, I am guessing. I'm sure some others as well.
It's been discussed on the forums previously.
fastest way to test streams:
Re: recording sound
This will be in 1.35/1.36. Maybe in the next month or so. It's a solid days work for sure.
