Edit login page for zoneminder?
david1234
Post by david1234 »
Hello ,
I want to make the login page more personal ,
where do I find the index.html of it?
/var/www/
no folder called zm
am I lokking at the right place?
Thanks ,
alabamatoy
Re: Edit login page for zoneminder?
Post by alabamatoy »
Try
/usr/share/zoneminder/www/skins/classic/views/login.php
If you are using a different skin then "classic" in the above line may be something else.
david1234
Post by david1234 »
Thank you!
