current running state display
zd59
Post by zd59 »
In zm-1-30.0 the web console shows run state as is with saved text.
For example: I saved states "live_view" and "away" as states, where cameras shows only current video without motion detection, and another where motion detection is active and saves events.
The WEB console correctly show the above states as "live_view" or "away".
In ZM-1.33.x the only possible state displayed are "RUNNING" and "STOPPED". When I save the above states (live_view and away) and activate each, both are displayed as "RUNNING". Is this a new feature or bug?
If it's a feature, please add below current state a "sub-state" that reflects manually saved and activated state.
Re: current running state display
I just saved a run state and attempted to use it. The save seems to have worked, although when attempting to apply the saved run state only "Running" is shown. So it seems not to be working and I would consider this a bug.
My tests are done with ZM 1.33.8
zd59
Post by zd59 »
Thank you for a reply.
Pointing out, that state is changed, only display of status is wrong.
When selecting saved state the one did change (cameras functions changed according to saved state), only display status is always "running" for a different saved but running states.
I have brought it to the developer's attention and lets see if a bug report should be submitted
UPDATE: a PR has been created for a fix by the main developer.
zd59
Post by zd59 »
Thank you Rockedge!
Glad to help with malfunctions discovery, to improve this excellent product.
Best regards to all contribute to it!
