ZM 1.32.3 (and 1.33.1) - bug on replay recorded JPEG images
Re: ZM 1.32.3 and 1.33.1 - record MJPEG images
No...but actually the fact that there are only 1-2 core developers and the couple of others volunteer time to test and respond to the many forum requests....try to get to the bottom of everyone's problem.
So relax....I will look into your problem here because I have seen almost all of them.
can you see any recorded jpeg images in the events directory that corresponds to the recorded event?
I have as default storage /var/cache/zoneminder/events
Yes, recording jpegs (many and many jpegs, frustrating) work fine.
I confirm. In the folder there are many jpegs.
The strange is it's possible to play the stream, and record it in jpegs. But not possible to replay what recorded on jpegs.
My impression is the bug (if a bug) has not been still collected from ZM developers/testers since not frequent: only on ARM (X264 is not compatible on ARM, so Video writer is disabled on ARM) and on MJPEG cameras.
thanks
thanks
@rockedge, I have an update.
I installed VMware on my laptop (an Intel i5 6300U) and a fresh Ubuntu 18.04.
Then I installed ZM 1.32.3 following exactly the intructions/script at https://wiki.zoneminder.com/Ubuntu_Serv ... e_easy_way
So, for my MJPEG camera I'm able to replay the recorded streams if setting Save Jpeg = disabled and Video writer = X264 Encode (on this platform it is enabled)
if trying to set Save Jpeg = all possible values different from disabled and Video writer = disabled, I'm able to see all jpegs in /var/cache/zoneminder/events through the ls command, but I'm not able to replay the recorded JPEG images (exactly as it happens for the Odroid ARM board).
So it seems a bug on all platforms, not only on ARM. For platforms different by ARM it's not a big issue since there is a workaround: to use Video writer = X264 Encode (because enabled on all platform different by ARM); but on ARM platform is a roadblock.
I don't think it's an error of mine installing ZM since I exactly followed the instrctions/script mentioned above!
Is it possible none tested the case "MJPEG camera and Save Jpeg enabled" ??!?
It's a roadbloack for all owners of ARM boards (Raspberry, Odroid, ...) and MJPEG cameras. Not possible to replay recorded events on 1.32 and following versions! The only workaround -I found- is to go back 1.30.4 (probably the most stable version ever built), but that's unbelievable a regression on what already working well.
Please let me know. thanks
EDIT: moreover ZM 1.32 is able to generate a video from recorded JPEG images through the Video button. And then downloading the video it's possible to see it! So it seems ZM 1.32 correctly records jpeg images, but it's not able to view them clicking directly on the recorded event (note that it works in ZM 1.30.4!!).
Re: ZM 1.32.3 (and 1.33.1) - bug on replay recorded JPEG images
When viewing a .mp4 we just send the .mp4 to the browser. WHen viewing jpegs we use the cgi program zms. If your cgi paths are not correct in apache config, then zms doesn't get run and you don't get to view the event. This is literally reported every day here. Which is why we have such a long detailed error message which every still doesn't read.
There should be a line in your apache config for zoneminder /etc/apache2/conf-enabled/zoneminder.conf ? That says
ScriptAlias "/zm/cgi-bin/" "/usr/lib/zoneminder/cgi-bin/"
If you are not using the /zm at the end of the url you can add another
ScriptAlias /cgi-bin /usr/lib/zoneminder/cgi-bin/
Hi Isaac, thanks for your answer.
I'm sorry but I cannot understand how hell for a fresh Ubuntu install and a fresh ZM install (according to the script provided on the wiki) I could modify the variables you are mentioning. And I have to be treated like a stupid.
Probably i'm a stupid newbie but you are forgetting the free spirit and the reason you started to develop ZM.
Anyway before disturbing you I already read the reccomendation at https://zoneminder.readthedocs.io/en/la ... untu-18-04 at chapter Socket_sendto or no live streaming
I have no issue on live MJPEG streaming, it is only on recorded JPEG (from mjpeg stream). Anyway:
First, the recommendation is valid for 1.30.4 since in 1.32 there is no more Paths sheet in Options.
Second, I found for 1.32 /etc/zm/conf.d/01-system-paths.conf (i hope i found the correct file) and I checked into it:
# ZoneMinder url path to the zms streaming server
ZM_PATH_ZMS=/zm/cgi-bin/nph-zms
I think it is correct.
In my /etc/apache2/conf-enabled/zoneminder.conf I have:
note: without "" before and at the end of /zm/cgi-bin
I'm able to view and NOT able to replay mjpeg stream.
I receive the warn/error msg in the log console:
and in the apache error.log
it seem waiting for data, but data are present:
I tried too, as you suggested, ScriptAlias /cgi-bin "/usr/lib/zoneminder/cgi-bin"
i'm NOT able to view and NOT able to replay mjpeg stream
I checked too the contents of /usr/lib/zoneminder/cgi-bin:
is that correct? I think yes.
if you want I could expose my board for your check.
I could pay for support.
thanks
2019-04-27 19:36:52 web_js 3554 ERR getCmdResponse stream error: No data to read from socket - checkStreamForErrors() ?view=event
2019-04-27 19:36:52 web_php 3554 ERR No data to read from socket /usr/share/zoneminder/www/includes/functions.php 2048
2019-04-27 19:36:52 web_php 3554 ERR Timed out waiting for msg /var/run/zm/zms-363525s.sock /usr/share/zoneminder/www/ajax/stream.php 90
2019-04-27 19:36:07 zmdc 3392 WAR Can't find process with command of 'zma -m 1' zmdc.pl
2019-04-27 19:35:43 zmdc 3392 WAR Can't find process with command of 'zma -m 1' zmdc.pl
[Sat Apr 27 18:33:42.760038 2019] [cgi:warn] [pid 3502] [client 192.168.1.97:57956] AH01220: Timeout waiting for output from CGI script /usr/lib/zoneminder/cgi-bin/nph-zms, referer: http://192.168.1.208/zm/?view=event&eid=7&filter[Query][terms][0][attr]=MonitorId&filter[Query][terms][0][op]=%3d&filter[Query][terms][0][val]=1&page=1&popup=1
root@odroidxu4:/var/cache/zoneminder/events# ls /var/cache/zoneminder/events/IndoorZonagiorno/2019-04-27/9/
00001-capture.jpg 00018-capture.jpg 00035-capture.jpg 00052-capture.jpg 00069-capture.jpg 00086-capture.jpg 00103-capture.jpg 00120-capture.jpg 00137-capture.jpg
00002-capture.jpg 00019-capture.jpg 00036-capture.jpg 00053-capture.jpg 00070-capture.jpg 00087-capture.jpg 00104-capture.jpg 00121-capture.jpg 00138-capture.jpg
00003-capture.jpg 00020-capture.jpg 00037-capture.jpg 00054-capture.jpg 00071-capture.jpg 00088-capture.jpg 00105-capture.jpg 00122-capture.jpg 00139-capture.jpg
00004-capture.jpg 00021-capture.jpg 00038-capture.jpg 00055-capture.jpg 00072-capture.jpg 00089-capture.jpg 00106-capture.jpg 00123-capture.jpg 00140-capture.jpg
00005-capture.jpg 00022-capture.jpg 00039-capture.jpg 00056-capture.jpg 00073-capture.jpg 00090-capture.jpg 00107-capture.jpg 00124-capture.jpg 00141-capture.jpg
00006-capture.jpg 00023-capture.jpg 00040-capture.jpg 00057-capture.jpg 00074-capture.jpg 00091-capture.jpg 00108-capture.jpg 00125-capture.jpg 00142-capture.jpg
00007-capture.jpg 00024-capture.jpg 00041-capture.jpg 00058-capture.jpg 00075-capture.jpg 00092-capture.jpg 00109-capture.jpg 00126-capture.jpg 00143-capture.jpg
00008-capture.jpg 00025-capture.jpg 00042-capture.jpg 00059-capture.jpg 00076-capture.jpg 00093-capture.jpg 00110-capture.jpg 00127-capture.jpg 00144-capture.jpg
00009-capture.jpg 00026-capture.jpg 00043-capture.jpg 00060-capture.jpg 00077-capture.jpg 00094-capture.jpg 00111-capture.jpg 00128-capture.jpg 00145-capture.jpg
00010-capture.jpg 00027-capture.jpg 00044-capture.jpg 00061-capture.jpg 00078-capture.jpg 00095-capture.jpg 00112-capture.jpg 00129-capture.jpg 00146-capture.jpg
00011-capture.jpg 00028-capture.jpg 00045-capture.jpg 00062-capture.jpg 00079-capture.jpg 00096-capture.jpg 00113-capture.jpg 00130-capture.jpg 00147-capture.jpg
00012-capture.jpg 00029-capture.jpg 00046-capture.jpg 00063-capture.jpg 00080-capture.jpg 00097-capture.jpg 00114-capture.jpg 00131-capture.jpg 00148-capture.jpg
00013-capture.jpg 00030-capture.jpg 00047-capture.jpg 00064-capture.jpg 00081-capture.jpg 00098-capture.jpg 00115-capture.jpg 00132-capture.jpg 00149-capture.jpg
00014-capture.jpg 00031-capture.jpg 00048-capture.jpg 00065-capture.jpg 00082-capture.jpg 00099-capture.jpg 00116-capture.jpg 00133-capture.jpg 00150-capture.jpg
00015-capture.jpg 00032-capture.jpg 00049-capture.jpg 00066-capture.jpg 00083-capture.jpg 00100-capture.jpg 00117-capture.jpg 00134-capture.jpg
00016-capture.jpg 00033-capture.jpg 00050-capture.jpg 00067-capture.jpg 00084-capture.jpg 00101-capture.jpg 00118-capture.jpg 00135-capture.jpg
00017-capture.jpg 00034-capture.jpg 00051-capture.jpg 00068-capture.jpg 00085-capture.jpg 00102-capture.jpg 00119-capture.jpg 00136-capture.jpg
root@odroidxu4:/var/cache/zoneminder/events# ls /var/cache/zoneminder/events/1/2019-04-27/9/
odroid@odroidxu4:~$ ls -lh /usr/lib/zoneminder/cgi-bin
total 1.1M
lrwxrwxrwx 1 root root 3 Dec 8 17:06 nph-zms -> zms
-rwxr-xr-x 1 root root 1.1M Dec 8 17:06 zms
thanks
you know if I remember correctly...a while ago I could see a live stream...also record an event but i could not replay the event as an mp4 or jpeg.....I think I fixed it by finding out I was missing a library but I don't remember the specific one. I will try to recall what I did to fix it...I do remember it was a simple fix.
hi rock,
you touched the point!
Able to see the live MJPEG stream, but not able to replay the recorded JPEG images.
The only difference: in case of ffmpeg camera, I'm able to replay the mp4 recorded file.
It's not a matter of the specific path of nph-zms differently I should not be able to see the live MJPEG stream.
There should be a difference between the developers platform and a fresh platform.
Debugging on a fresh platform like I described (wmware, new ubuntu 18.04, LAMP, script on wiki) it should be easy to check the error. Unfortunately I'm not expert on this technology.
Please, if you will remember the library to be installed let me know. Not nly for me, but for other users in the same situation.
thanks
thanks
You are right, if live view works, the the zms path is correct.
Here's another thought: Is AUTH_HASH_LOGINS on? Options->SYstem->AUTH_HASH_LOGINS
I seem to remember a case where we weren't doing auth correctly without hash logins...
Are you using auth at all?
Please update to latest master, it has a lot of fixes since 1.33.1
Isaac, thanks for the answer.
Unfortunately AUTH_HASH_LOGINS is OFF.
I'm testing without AUTH at all.
I will try to install 1.33 from scratch and I will let you konow.
Pat i ve already try 1.33.6 and the issue persist....
when viewing an Event you can play the mp4 but what are you doing to play the jpegs?
Can you use the Stills button to view the individual jpegs?
yes, confirmed.
Just installed the last ZM 1.33.6 on a fresh ubuntu 18.04 on Odroid XU4 (ARM processor).
Able to see the mjpeg live stream, not able to replay the recorded jpegs. Even if present the jpg files in /var/cache/zoneminder/events.
yes, I can replay mp4 when the source is ffmpeg.
when the source is mjpeg, since I'm on ARM platfrom, the only option is to save jpegs. and the image remains blocked.
i see the event with the thumbnail.
Interesting:
If I push Stills button, the first 7 x 14 +1 (=99) individual jpegs are grayed, the remaining (from 100 to 303) are correct!
I can scroll with >> and << buttons. The others buttons are disabled.
note: differently from 1.32.3, with 1.33.6 I'm not able to generate a video. It remains in "Generating video..." status.
thanks
Interesting:
thanks
the fact that you can not create the video is a sign something is not right. Does the export function work?
I seem to remember the permissions and ownership of some directories were incorrect which caused it....but this could also be something else...I ran into all kinds of problems figuring out how to install and run ZM on different Puppy Linux variations...and what you describe was one of them.
Users browsing this forum: No registered users and 13 guests
