Problem with analysis images
Running ZM 1.32.3 on CentOS 7.5 and trying to fine tune my motion detection. I am getting a large number of false positives where I cannot discern
any motion from the playback. I would like to turn on "analysis frame" creation and have checked the box on the Options>Config screen and saved but none of the monitors show any analysis frames when stepping through the event frames. Tried unchecking the box with the same result.
Is "CREATE_ANALYSIS_IMAGES" working in 1.32.3? How can I troubleshoot this?
Thank you for your suggestions.
Kory
Kory
Re: Problem with analysis images
Yeah, on Debian 9 I'm also seeming to be missing this ability (though I have CREATE_ANALYSIS_IMAGES enabled).
OK. So maybe not just me. Anyone else?
- knight-of-ni
Open Monitor Config -> Storage tab -> Enable Analysis Image jpegs
Your motion zones also need to have the Blob method enabled.
Yup, that did the trick. Would be good to add that to the pop-up help for Create_Aanalysis_Images. I would be happy to add it if I knew how to get it in there. Say perhaps:
Note:To enable creation of analysis images, set Save JPEGs to Analysis images only or to Frames + Analysis images on the Storage tab of Monitor Definition (Source).
Or I suppose the code could be updated to override the Save JPEGs setting behind the scenes when the Create_Analysis_Images box is checked.
Anyway, thanks for the tip.
- knight-of-ni
CREATE_ANALYSIS_IMAGES will not not be present in the next release.
This is a work in progress while we transition from jpeg -> mp4 so some things overlap at the moment.
Does that mean we won't be able to see the analysis frames when trying to tune the zones ?
- knight-of-ni
No. It means the setting is per camera rather than global.
Users browsing this forum: No registered users and 9 guests
