api and nginx
abi
api and nginx
Post by abi » Tue Nov 13, 2018 10:00 pm
Hello, can you give me tip how to setup api with nginx ?
Warning (2): require_once(../../../includes/config.php): failed to open stream: No such file or directory [APP/Config/bootstrap.php, line 123]
Fatal error: require_once() [function.require]: Failed opening required '../../../includes/config.php' (include_path='.:/usr/local/share/pear') in /usr/local/www/zoneminder/api/app/Config/bootstrap.php on line 123
Notice (8): Use of undefined constant ZM_OPT_USE_API - assumed 'ZM_OPT_USE_API' [APP/Controller/AppController.php, line 63]
Notice (8): Use of undefined constant ZM_OPT_USE_AUTH - assumed 'ZM_OPT_USE_AUTH' [APP/Controller/AppController.php, line 72]
Warning (2): require_once(../../../includes/auth.php) [<a href='http://php.net/function.require-once'>function.require-once</a>]: failed to open stream: No such file or directory [APP/Controller/AppController.php, line 73]
Fatal error: require_once() [function.require]: Failed opening required '../../../includes/auth.php' (include_path='.:/usr/local/share/pear') in /usr/local/www/zoneminder/api/app/Controller/AppController.php on line 73
I use example from this distro https://github.com/ZoneMinder/zoneminde ... onf.in#L50
This looks impossible - getcwd() is /usr/local/www/zoneminder/api with this rewrite, so ../../../ is obviously wrong.
Full config (ZM web interface is fully operational with this one, only api throws errors):
server {
    listen 80;
    location /cgi-bin/nph-zms {
        gzip off;
        root /usr/local/www/zoneminder;
        include fastcgi_params;
        fastcgi_param SCRIPT_FILENAME $request_filename;
        fastcgi_pass  unix:/var/run/fcgiwrap/fcgiwrap.sock;
    location /zm/cache {
        alias /var/cache/zoneminder;
    location /zm {
        gzip off;
        alias                   /usr/local/www/zoneminder;
        index                   index.php;
        location ~ \.php$ {
            if (!-f $request_filename) { return 404; }
            fastcgi_index index.php;
            fastcgi_pass unix:/var/run/php-fpm.sock;
        location ~ \.(jpg|jpeg|gif|png|ico)$ {
            access_log          off;
            expires         33d;
        location /zm/api/ {
            rewrite ^/zm/api(.+)$ /zm/api/index.php?p=$1 last;
abi
Re: api and nginx
Post by abi » Tue Nov 13, 2018 10:10 pm
Maybe, I should rewrite to api/app/webroot/index.php ?
Nocifer
Re: api and nginx
Post by Nocifer » Wed Nov 14, 2018 3:31 pm
Yes, this specific error can be fixed by rewriting to 'api/app/webroot' instead of just 'api'.
Pedulla
Re: api and nginx
Post by Pedulla » Sun Nov 18, 2018 8:47 am
@api
Do you mind sharing how you got ZM to work on ngnix?
I've yet to figure this one out.
Re: api and nginx
Post by knight-of-ni » Sun Nov 18, 2018 6:35 pm
I just finished splitting the official zoneminder rpm into apache and nginx subpackages. I was testing the nginx portion for the first time when I noticed the api support in the nginx config was broken. I knew there was some existing conversation in the user forum so I went looking for a quick fix.
Sure enough, changing the rewrite fixed the issue. Thank you.
The nginx config for redhat lives here now:
https://github.com/ZoneMinder/zoneminde ... nx.conf.in
I had to move several config files around and rename them slightly in order to make the rpm subpackages build.
abi
Re: api and nginx
Post by abi » Sun Nov 18, 2018 10:20 pm
@api
Here is nginx config for backend. ZMNinja works with this config. There are no gotchas at all, probably the only one is fcgiwrap children number (default value is 1).
server {
    listen 80;
    index index.php;
    gzip off;
    location / {
        return 301 /zm;
    location /zm {
        location ~ \.php$ {
            access_log  off;
            expires     33d;
        location /zm/api/ {
            rewrite ^/zm/api(.+)$ /zm/api/app/webroot/index.php?p=$1 last;
I have a reverse proxy, that strips https, but it's pretty straightforward.
Pedulla
Re: api and nginx
Post by Pedulla » Mon Nov 19, 2018 12:57 am
Not to be dense, but I'll be dense...
Is this the entirety of the /etc/nginix/nginx.conf or is this an include conf in the .../sites-enabled/ ?
abi
Re: api and nginx
Post by abi » Mon Nov 19, 2018 6:45 am
Include it was.
Here is my nginx.conf
user  www;
worker_processes  1;
error_log  /var/log/nginx/error-default.log;
pid        /var/run/nginx.pid;
events {
    worker_connections  1024;
http {
    include       mime.types;
    default_type  application/octet-stream;
    log_format  main  '$remote_addr - $remote_user [$time_local] "$request" '
                      '$status $body_bytes_sent "$http_referer" '
                      '"$http_user_agent" "$http_x_forwarded_for"';
    sendfile on;
    tcp_nopush on;
    tcp_nodelay on;
    server_tokens off;
    include /usr/local/etc/nginx/sites/*;
You may remove all ssl and gzip stuff though.
Users browsing this forum: No registered users and 0 guests
