Install Zoneminder with shell script fails date.timezone
MoOz
Post by MoOz »
Install Zoneminder on Ubuntu 18.04 with shell script
wiki.zoneminder.com/Ubuntu_Server_18.04_64-bit_with_Zoneminder_1.32.0_the_easy_way
fails to install Date.timezone
nothing changes in the php.ini file
have to edit manually
awk '$0="date.timezone = "$0' /etc/timezone >> /etc/php/7.2/apache2/php.ini
can you enter the your timezone in the script ?
Re: Install Zoneminder with shell script fails date.timezone
Check the end of the file. The script appends the timezone to the end of the file.
Edit: I ran that script yesterday with no issues. I did edit it to use zoneminder-master.
MoOz
Post by MoOz »
ok thanks
i get time zone fail when i run zoneminder
i will look at the bottom of the file next time
