Blue Screen on feed from remote dvr
I'm trying to connect a DVR to Zoneminder. The video path I've figured out for the DVR is "http://192.168.0.24/cgi-bin/view.cgi?ch ... p=password" Opening that path in a browser causes a file to start start downloading on my computer. The file is called "View.cgi" I am able to open this file in VLC and see the video.
Now when I open zone minder and set up a monitor with the source as "remote", the host as "192.168.0.24", the port as "80" and the path as "/cgi-bin/view.cgi?chn=1&u=admin&p=password" I just end up with a blue screen in the monitor. Ive tried all the other source options to no avail.
I'm running CentOS 7.
Please tell me what I'm doing wrong.
Re: Blue Screen on feed from remote dvr
the screen resolution must be correctly set in ZM for what the DVR is streaming out. THe blue screen is a sure sign that all that needs to be adjusted is the resolution....remember it must match...you say you can see in VLC? then use VLC to determine the correct resolution and use that in the ZM setup for the DVR
VLC shows the video file to be 704x480 resolution. I set this as the resolution in the zoneminder monitor and I just get a larger blue screen.
what happens if you try to open the url
in the browser?
Can you enter the stream directly in vlc?
If I enter "http://192.168.0.24/cgi-bin/view.cgi?ch ... p=password" into my browser, Firefox starts downloading a file called "view.cgi" I can open that file in VLC. I have not been able to get VLC to open the stream directly.
That would mean the cameras stream live to the DVR, the DVR is recording the camera streams? Zoneminder is then supposed to open this url download the file and view it and possibly do motion detection. I do not think can process a file of a recorded stream like that. What is your overall goal? Perhaps there are other streams being generated but use a slightly different URL. But it seems redundant to network a DVR to Zoneminder.... which is in principle a network video recorder
My company has several DVRs with out hard drives connected to analogue NTSC cameras, as well as a number of newer IP cameras spread around several remote locations and our main building. We use zoneminder to centrally record and monitor the video feeds from the DVRs and IP cameras that are spread around our network.
We have one location that has an off brand DVR that I am having trouble getting the video feed from. all the other DVRs and cameras output RTSP streams, which are easy enough to capture on zoneminder.
If no one knows of a way to record the "view.cgi" file that I am having trouble getting zoneminder to work with I will just advise that the dvr be replaced with something I can get an RTSP stream from.
Have you taken a look at the content of the view.cgi file, there may be clues as to how your camera feeds are streamed. or better still publish the file on here for other to help you.
You know the reason for things not working is likely in the logs. Look in them.
Users browsing this forum: No registered users and 14 guests
