Problems with multiple high resolution cameras
robfish
Post by robfish »
I am posting this info as it may be helpful for other "newbies" like me:-
I just installed my fourth 8 Megapixel camera but had trouble obviously overloading my Zoneminder.
The fix was to lower the resolution. I found that various combinations worked (lower res on all or have a mixture).
inis
Re: Problems with multiple high resolution cameras
Post by inis »
What are your machine specs?
High res cameras require more RAM. Specifically more tmpfs. By default many Linux distros allocate half of the installed RAM for tmpfs. If you are an old school DOS person think RAM drive. Zoneminder 1.30.4 shows the space used in tmpfs or /dev/shm. Adding one more camera at high res can bring Zoneminder down. Yes, adding more RAM can help and you can also reallocate more RAM to tmpfs but this is at the peril of starving other processes, like the SQL database, of memory.
robfish
Post by robfish »
system HP Compaq 6000 Pro SFF PC (VP751PA#ABG)
/0 bus 3048h
/0/1 memory 128KiB BIOS
/0/5 processor Intel(R) Core(TM)2 Quad CPU Q9400 @ 2.66GHz
/0/5/6 memory 256KiB L1 cache
/0/5/7 memory 6MiB L2 cache
/0/38 memory System Memory
/0/38/0 memory 1GiB DIMM DDR3 Synchronous 1333 MHz (0.8 ns)
/0/38/1 memory 2GiB DIMM DDR3 Synchronous 1333 MHz (0.8 ns)
/0/38/2 memory 1GiB DIMM DDR3 Synchronous 1333 MHz (0.8 ns)
/0/38/3 memory 2GiB DIMM DDR3 Synchronous 1333 MHz (0.8 ns)
/0/39 memory Flash Memory
/0/39/0 memory 4MiB Chip FLASH Non-volatile
/0/3 scsi2 storage
/0/3/0.0.0 /dev/sda disk 320GB SAMSUNG HD321HJ
/0/3/0.0.0/1 /dev/sda1 volume 292GiB EXT4 volume
/0/3/0.0.0/2 /dev/sda2 volume 6014MiB Extended partition
/0/3/0.0.0/2/5 /dev/sda5 volume 6014MiB Linux swap volume
thegizzard
Post by thegizzard »
Rob, I may have a similar problem. Do you mind sharing the model and configuration you have for your cameras?
I have 2 x 1.3mp Amcrest Cameras, 1 x 3MP Amcrest Dome, 1x 2MP Hikvision Doorbell, 1 new 4K (8MP) Amcrest.
I am using FFMPEG on all of them. What is your setup for your 8MP camera? and which model do you have?
robfish
Post by robfish »
I have 3 x HikVision DS-2CD2085FWD-I IP Cameras an an old phone with IPWebcam in the garage.
The HikVision cameras default to 8 Mega pixels. I have played around a bit and now have them working fine, all on 3072x1728 (5.3 MP)
thegizzard
I just got mine up to 3072x2048, no errors. Thanks for the tip.
robfish wrote: Fri Jun 01, 2018 10:11 pm I have 3 x HikVision DS-2CD2085FWD-I IP Cameras an an old phone with IPWebcam in the garage.
Pedulla
Post by Pedulla »
You can also lower the ring buffer and pre-event frames to lower the tmpfs used.
These settings are on the Buffers tab of the source setup link.
