'There are no statistics recorded for this event/frame'?
unclerichy
Post by unclerichy »
I've turned on the statistic logging so that I can fiddle with zone settings but it doesn't log any stats at all. It used to work when I installed my first copy of ZM (pre 1.19 I think) but doesn't seem to work now (1.19.3)
Any suggestions?
seb
Post by seb »
Same problem here..
Nothing in the logs..
seb
Post by seb »
Figured it out !
You need ZM_CREATE_ANALYSIS_IMAGES to be ON for it to store info in the stats table..
ZM_RECORD_EVENT_STATS
This version of ZoneMinder records detailed information about events in the Stats table. This can help in profiling what the optimum settings are for Zones though this is tricky at present. However in future releases this will be done more easily and intuitively, especially with a large sample of events. The default option of 'yes' allows this information to be collected now in readiness for this but if you are concerned about performance you can switch this off in which case no Stats information will be saved.
:P
