Budget 4-port card in the UK?
aris
Post by aris »
I'm looking for a budget 4-port card which is compatible with Zoneminder. What are my options? I see there is one for sale on this website - but no stock at the moment.
I found these:
Euresys Picolo Pro 2 for about 180 pounds
or I thought perhaps I could get away with putting 4 Hauppague WinTV GO's in one machine - would this work?
Any others available?
lazyleopard
Post by lazyleopard »
You might want to try looking for one without a TV tuner, like the "WinTv-Impact VCB", as you get an extra composite input instead. However, they share one BTTV chip between the inputs so the frame rate goes down significantly if you use two (or more) inputs on one card.
Rick Hewett
