Download clip throws -> Unknown function call Object->GenerateVideo from Array
ihavealegohead
Post by ihavealegohead »
Installed ZoneMinder 1.37.47 on a new Ubuntu 22.04.3 LTS
Added a few cam's and then tried to download a video clip.
The zip file does not contain the mp4 file. Checked the log file found:
==> /var/log/zm/web_php.log <==
11/29/23, 4:41:00 PM MST.879482 web_php[1445].ERR [x.x.x.x] [ZoneMinder is not configured properly: php's date.timezone -0700 does not match the system timezone +0000! Please check Options->System->Timezone.] at /usr/share/zoneminder/www/includes/functions.php line 2046
11/29/23, 4:41:02 PM MST.180508 web_php[1445].WAR [x.x.x.x] [Unknown function call Object->GenerateVideo from Array
    [0] => Array
            [file] => /usr/share/zoneminder/www/includes/download_functions.php
            [line] => 74
            [function] => __call
            [class] => ZM\ZM_Object
            [object] => ZM\Event Object
                    [_last_error:protected] =>
                    [Tags:protected] =>
                    [Event_Tags:protected] =>
                    [defaults:protected] => Array
                            [Id] =>
                            [Name] =>
                            [MonitorId] =>
                            [StorageId] =>
                            [SecondaryStorageId] =>
                            [Cause] =>
                            [StartDateTime] =>
                            [EndDateTime] =>
                            [Width] =>
                            [Height] =>
                            [Length] =>
                            [Frames] =>
                            [AlarmFrames] =>
                            [DefaultVideo] =>
                            [SaveJPEGs] => 0
                            [TotScore] => 0
                            [AvgScore] => 0
                            [MaxScore] => 0
                            [Archived] => 0
                            [Videoed] => 0
                            [Uploaded] => 0
                            [Emailed] => 0
                            [Messaged] => 0
                            [Executed] => 0
                            [Notes] =>
                            [StateId] => 0
                            [Orientation] => 0
                            [DiskSpace] =>
                            [Scheme] => 0
                            [Locked] => 0
                    [Id] => 10
                    [MonitorId] => 3
                    [StorageId] => 0
                    [SecondaryStorageId] => 0
                    [Name] => Event-10
                    [Cause] => Motion
                    [StartDateTime] => 2023-11-29 22:03:08
                    [EndDateTime] => 2023-11-29 22:03:17
                    [Width] => 1920
                    [Height] => 1080
                    [Length] => 9.59
                    [Frames] => 193
                    [AlarmFrames] => 96
                    [DefaultVideo] =>
                    [SaveJPEGs] => 3
                    [TotScore] => 1187
                    [AvgScore] => 12
                    [MaxScore] => 21
                    [Archived] => 0
                    [Videoed] => 0
                    [Uploaded] => 0
                    [Emailed] => 0
                    [Messaged] => 0
                    [Executed] => 0
                    [Notes] => Motion: All
                    [StateId] => 1
                    [Orientation] => ROTATE_0
                    [DiskSpace] => 64218908
                    [Scheme] => Medium
                    [Locked] => 0
                    [Latitude] =>
                    [Longitude] =>
            [type] => ->
            [args] => Array
                    [0] => GenerateVideo
                    [1] => Array
    [1] => Array
            [file] => /usr/share/zoneminder/www/ajax/event.php
            [line] => 152
            [function] => exportEvents
            [args] => Array
                    [0] => Array
                            [0] => 10
                            [1] => 23
                            [2] => 24
                    [1] => zmDownload-492449
                    [2] => zip
                    [3] =>
    [2] => Array
            [file] => /usr/share/zoneminder/www/index.php
            [line] => 260
            [args] => Array
                    [0] => /usr/share/zoneminder/www/ajax/event.php
            [function] => require_once
)] at /usr/share/zoneminder/www/includes/Object.php line 89
11/29/23, 4:41:02 PM MST.192511 web_php[1445].WAR [x.x.x.x] [Unknown function call Object->GenerateVideo from Array
    [0] => Array
            [line] => 74
                    [Tags:protected] =>
                            [Id] =>
                            [Name] =>
                            [MonitorId] =>
                            [StorageId] =>
                            [Cause] =>
                            [StartDateTime] =>
                            [EndDateTime] =>
                            [Width] =>
                            [Height] =>
                            [Length] =>
                            [Frames] =>
                            [AlarmFrames] =>
                            [DefaultVideo] =>
                            [SaveJPEGs] => 0
                            [TotScore] => 0
                            [AvgScore] => 0
                            [MaxScore] => 0
                            [Archived] => 0
                            [Videoed] => 0
                            [Uploaded] => 0
                            [Emailed] => 0
                            [Messaged] => 0
                            [Executed] => 0
                            [Notes] =>
                            [StateId] => 0
                            [Orientation] => 0
                            [DiskSpace] =>
                            [Scheme] => 0
                            [Locked] => 0
                    [Id] => 23
                    [MonitorId] => 3
                    [StorageId] => 0
                    [Name] => Event-23
                    [Cause] => Motion
                    [StartDateTime] => 2023-11-29 22:59:52
                    [EndDateTime] => 2023-11-29 23:00:01
                    [Width] => 1920
                    [Height] => 1080
                    [Length] => 9.63
                    [Frames] => 194
                    [AlarmFrames] => 115
                    [DefaultVideo] =>
                    [SaveJPEGs] => 3
                    [TotScore] => 1338
                    [AvgScore] => 11
                    [MaxScore] => 27
                    [Archived] => 0
                    [Videoed] => 0
                    [Uploaded] => 0
                    [Emailed] => 0
                    [Messaged] => 0
                    [Executed] => 0
                    [StateId] => 1
                    [DiskSpace] => 68312658
                    [Scheme] => Medium
                    [Locked] => 0
                    [Latitude] =>
                    [Longitude] =>
            [type] => ->
            [args] => Array
                    [1] => Array
    [1] => Array
            [line] => 152
            [args] => Array
                    [0] => Array
                            [0] => 10
                            [1] => 23
                            [2] => 24
                    [2] => zip
                    [3] =>
    [2] => Array
            [line] => 260
            [args] => Array
11/29/23, 4:41:02 PM MST.199685 web_php[1445].WAR [x.x.x.x] [Unknown function call Object->GenerateVideo from Array
    [0] => Array
            [line] => 74
                    [Tags:protected] =>
                            [Id] =>
                            [Name] =>
                            [MonitorId] =>
                            [StorageId] =>
                            [Cause] =>
                            [StartDateTime] =>
                            [EndDateTime] =>
                            [Width] =>
                            [Height] =>
                            [Length] =>
                            [Frames] =>
                            [AlarmFrames] =>
                            [DefaultVideo] =>
                            [SaveJPEGs] => 0
                            [TotScore] => 0
                            [AvgScore] => 0
                            [MaxScore] => 0
                            [Archived] => 0
                            [Videoed] => 0
                            [Uploaded] => 0
                            [Emailed] => 0
                            [Messaged] => 0
                            [Executed] => 0
                            [Notes] =>
                            [StateId] => 0
                            [Orientation] => 0
                            [DiskSpace] =>
                            [Scheme] => 0
                            [Locked] => 0
                    [Id] => 24
                    [MonitorId] => 3
                    [StorageId] => 0
                    [Name] => Event-24
                    [Cause] => Motion
                    [StartDateTime] => 2023-11-29 23:00:06
                    [EndDateTime] => 2023-11-29 23:00:20
                    [Width] => 1920
                    [Height] => 1080
                    [Length] => 13.85
                    [Frames] => 278
                    [AlarmFrames] => 121
                    [DefaultVideo] =>
                    [SaveJPEGs] => 3
                    [TotScore] => 674
                    [AvgScore] => 5
                    [MaxScore] => 15
                    [Archived] => 0
                    [Videoed] => 0
                    [Uploaded] => 0
                    [Emailed] => 0
                    [Messaged] => 0
                    [Executed] => 0
                    [StateId] => 1
                    [DiskSpace] => 85133927
                    [Scheme] => Medium
                    [Locked] => 0
                    [Latitude] =>
                    [Longitude] =>
            [type] => ->
            [args] => Array
                    [1] => Array
    [1] => Array
            [line] => 152
            [args] => Array
                    [0] => Array
                            [0] => 10
                            [1] => 23
                            [2] => 24
                    [2] => zip
                    [3] =>
    [2] => Array
            [line] => 260
            [args] => Array
root@zoneminder:/usr/share/zoneminder# find . -type f -exec grep -iH 'GenerateVideo()' {} \;
./www/skins/classic/views/js/video.js:function generateVideo() {
./www/includes/download_functions.php: if (!$event->DefaultVideo()) $event->GenerateVideo();
I changed the function name in download_functions.php to generateVideo() - but this did not resolve the issue. I'll fix the timezone issue and see if that helps.
Any other Ideas?
Re: Download clip throws -> Unknown function call Object->GenerateVideo from Array
I think I never implemented that function. Because I save my video as mp4's.... so we don't need to generate the video... stay tuned.
I have now implemented that function. Downloading when storing jpegs should automatically generate a mp4 to download.
ihavealegohead
Confirmed it's working now - ty !
