Read This Before Posting
zoneminder
Site Admin
Post by zoneminder »
Before asking about a hardware support please check the Hardware Compatibility List first.
cordel
Post by cordel »
You should also check our Wiki HCL and the HCL for your Distro.
It's always a good idea to google on the hardware your considering just to make sure it has no problems. ie. in the google search string you could do
to search our domain only for other users experiences.
Lee Sharp
Post by Lee Sharp »
And when your card does not work, realize that there are hundreds of different cards. And each one is often branded with many different names. A name, link, and picture can really help a lot. If I see a post with "I have China Special PX-1234 and it doesn't work" and that is all, I have no answer to give.
caseyj
Re: Read This Before Posting
Post by caseyj »
Also
Before I try to get a camera to work on Zoneminder, I try to look at it using the Swiss Army Knife of video tools, the VLC Player. Just download the player and put the following url into the File/Open Network dialog box...
More... https://wiki.zoneminder.com/Dahua.. Look for
Confirming Camera is On Your Network
michael_80
Post by michael_80 »
Hi there,
Just wanted to let you know the link http://www.zoneminder.com/support.html you posted here is not working, it gives 404 Not Found.
whatzhisface
Post by whatzhisface »
The link in the initial "read this" post for checking hardware compatibility is broken.
I found this in the wiki https://wiki.zoneminder.com/Hardware_Compatibility_List
dvl
Post by dvl »
zoneminder wrote: Wed Apr 14, 2004 11:18 am Before asking about a hardware support please check here and in the Hardware Compatibility List first.
Both of these links are 404.
Dan Langille
First was easy to fix... not sure where the content for the second went...
