Good morning,
I recently upgraded my Debian to bookworm and at the same time php from version 7.4 to version 8.2.
I then upgraded zoneminder from version 1.34 to version 1.36.
The result is that now the cameras work but the web interface is ugly, I don't really know how to explain it. I attach a screen.
I have tried changing the theme, changing the browser and using incognito mode. Always the same result.
What could it be?
Thank you
Ugly web interface after upgrade
- Screen1.jpg (109.46 KiB) Viewed 23604 times
Re: Ugly web interface after upgrade
When you upgraded to Bookworm your existing Zoneminder was overwritten by the 1.36.x version in the Debian repository. Your best bet is to start with a fresh install of Debian 12 and install Zoneminder per the WIKI: https://wiki.zoneminder.com/Debian_12_B ... er_1.36.33
Or use the install procedure here (https://wiki.zoneminder.com/Debian_11_B ... der_1.36.x) as a starting point and install Zoneminder 1.37.x. Change the: deb https://zmrepo.zoneminder.com/debian/release-1.36 in the script to: deb https://zmrepo.zoneminder.com/debian/master
You are right. For some reason the cache path was wrong. Maybe it has changed in the last 2 versions? Just a guess.
Anyway, I solved it by changing the cache path in the apache configuration and the link of /usr/share/zoneminder/www/cache.
Thanks everyone!
