Control camera with the API
dinosaure
Post by dinosaure »
Hi all,
I'm using 1.36.33 version of zoneminder on debian bookworm.
I'm trying to use API zoneminder.
My nginx configuration have this lines for API.
Is it correct ?
location /zm/api {
         rewrite ^/zm/api(.+)$ /zm/api/app/webroot/index.php?p=$1 last;
I check all available camera with this command.
curl -d "username=user&password=mypassword&action=login&view=console" -c cookies.txt http://mydomain/zm/api/monitors.json
And i try to change the name of one camera.
curl -XPUT http://zone.freewind.fr/zm/api/monitors/8.json -d "Monitor[Name]=test1"
After checking with monitors.json, the name doesn't changed and nginx give the following result.
"PUT /zm/api/monitors/X.json HTTP/1.0" 200 8474 "-" "curl/7.88.1"
I'm using this documentation. It's a good one ?
https://sgzoneminder.readthedocs.io/en/ ... n/api.html
Have you an idea about this ?
Thanks a lot
burger
Re: Control camera with the API
Post by burger »
See https://wiki.zoneminder.com/API
Make sure nginx is configured properly with https://wiki.zoneminder.com/Debian_11_B ... der_1.36.x which should be close enough for bookworm (although no guarantees)
fastest way to test streams:
dinosaure
Post by dinosaure »
Thanks for your feedback.
I have tried to use the nginx configuration what you said.
When i try to acces to index.php, i have this nginx error log.
[error] 86425#86425: *17 directory index of "/usr/share/zoneminder/www/" is forbidden, client: XX.XX.XX.XX, server: XX.XX.XX.XX, request: "GET / HTTP/1.0", host: "XX.XX.XX.XX".
Why ? I don't know ! Because of a proxy_pass ? The user who use this directory is ? www-data ? Thanks a lot.
dinosaure
Post by dinosaure »
I have a good nginx configuration.
Now, i try this command. I delete /zm of the URL path.
curl -d "username=user&password=mypassword&action=login&view=console" -c cookies.txt http://mydomain/api/monitors.json
I have this log.
{"message":{"Name":["Monitor Name must be specified for creation","Monitor Name must be specified for creation"]}}
So i'm not authenticated, after i try this command.
curl http://server/api/host/getVersion.json
I have this log.
{"success":false,"data":{"name":"Not Authenticated","message":"Not Authenticated","url":"\/api\/host\/getVersion.json?p=%2Fhost%2FgetVersion.json","exception":{"class":"UnauthorizedException","code":401,"message":"Not Authenticated"}}}.
Have you an idea ? Thanks a lot
