It appears as though I have an upgrade to ZM to 1.37.33 and now I cannot seem to set the number of rows visible from 10 to showing all the events as I had before.
I have set the number of rows in the Options| Web| WEB_EVENTS_PER_PAGE to 0 or 100 or 10000000 and it always shows 10, which is annoying.
How might I correct this?
Many thanks,
Upgrade to 1.37.33 changed settings
Re: Upgrade to 1.37.33 changed settings
Works for me, did you get the update today?
Dear All,
its the same in 1.36.33, is there anything I have to check in addition?
Kind regards.
Heimo
Kind regards.
Heimo
