Having to delete tokens.txt every zmes restart
sphillips
Post by sphillips »
so im having a weird issue which the solution i could not find online, when first setting up tokens.txt events are sent and logs show no errors however when i restart zmeventnotification.pl events are no longer sent with errors such as
DBG-1:2022-10-24,03:41:12 PARENT: ES invoked manually. Will handle restarts ourselves
DBG-2:2022-10-24,03:41:12 PARENT: Parent<--Child pipe ready
INF:2022-10-24,03:41:12 PARENT: Event Notification daemon v 6.1.28 starting
10/24/2022 03:41:12.617856 zmeventnotification[41341].INF [main:1006] [PARENT: Event Notification daemon v 6.1.28 starting]
DBG-1:2022-10-24,03:41:12 PARENT: Initializing FCM tokens...
Use of uninitialized value $monlist in anonymous hash ({}) at /usr/bin/zmeventnotification.pl line 2867.
Use of uninitialized value $intlist in anonymous hash ({}) at /usr/bin/zmeventnotification.pl line 2867.
Use of uninitialized value $platform in anonymous hash ({}) at /usr/bin/zmeventnotification.pl line 2867.
Use of uninitialized value $pushstate in anonymous hash ({}) at /usr/bin/zmeventnotification.pl line 2867.
Use of uninitialized value $appversion in anonymous hash ({}) at /usr/bin/zmeventnotification.pl line 2867.
Odd number of elements in anonymous hash at /usr/bin/zmeventnotification.pl line 2867.
DBG-2:2022-10-24,03:41:17 PARENT: ----------> Tick START (active forks:0, total forks:0, active hooks: 0 running for:1 min)<--------------
Use of uninitialized value in numeric eq (==) at /usr/bin/zmeventnotification.pl line 2286.
Use of uninitialized value in numeric ne (!=) at /usr/bin/zmeventnotification.pl line 2315.
Use of uninitialized value in numeric eq (==) at /usr/bin/zmeventnotification.pl line 2318.
Use of uninitialized value in numeric eq (==) at /usr/bin/zmeventnotification.pl line 2321.
Use of uninitialized value in numeric eq (==) at /usr/bin/zmeventnotification.pl line 2324.
Use of uninitialized value in numeric eq (==) at /usr/bin/zmeventnotification.pl line 2327.
Use of uninitialized value in numeric eq (==) at /usr/bin/zmeventnotification.pl line 2330.
Use of uninitialized value in numeric eq (==) at /usr/bin/zmeventnotification.pl line 2336.
DBG-2:2022-10-24,03:41:17 PARENT: After tick: TOTAL: 2 , ES_CONTROL: 0, FCM+WEB: 0, FCM: 0, WEB: 0, MQTT:0, invalid WEB: 0, PENDING: 0
DBG-2:2022-10-24,03:41:17 PARENT: There are 0 active child forks & 0 zm_detect processes running...
DBG-2:2022-10-24,03:41:17 PARENT: checkEvents() new events found=0
DBG-2:2022-10-24,03:41:17 PARENT: There are 0 new Events to process
also
│zmeventnotification[35715]: ERR [|----> FORK:Frente (2), eid:37354 interval not found for mid 2]
│zmeventnotification[35715]: ERR [|----> FORK:Frente (2), eid:37354 FCM push message Error:400 Bad Request]
if i delete tokens.txt and create new entries all works fine till i restart zmeventnotification.pl
ENTIRE LOG
sphillips
Re: Having to delete tokens.txt every zmes restart
Post by sphillips »
ok just tested an older version of zmeventnotification.pl and all works fine, might be problems with the lastest changes to the file.
Development of ZMES stopped last year. I’d you have a workaround, that’s good.
sphillips
Post by sphillips »
Magic919 wrote: Mon Oct 24, 2022 4:39 pm Development of ZMES stopped last year. I’d you have a workaround, that’s good.
zmes development was not dropped, the original developer gave it up however zoneminder team picked it up.
a heads up the last changes on zmeventnotification seems to break zmeventnotification.pl
Version 6.1.28 is the last version Asker did.
I can see Isaac has merged a PR recently and maybe that's broken what you are running.
I'll stick with the old Asker version.
Was it just the last commit? Most of the changes have been white space changes etc. I don't see how the last commit could have any effect.
Mine here isn't complaining but then I'm not using fcm... perhaps I'll turn it back on
sphillips
Post by sphillips »
since u asked i tested the last 2 commits and issue still there for me.
i found that at this commit i start to see those "Use of uninitialized value" however fcm is working but with errors
│zmeventnotification[557378]: ERR [Error sending FCM for token:]
│zmeventnotification[557378]: ERR [Error value =InvalidRegistration]
│zmeventnotification[557378]: ERR [|----> FORK:SegundoAndar (3), eid:38415 interval not found for mid 3]
this commit does not show any errors and all works
i dunno if somebody could confirm same would be better, i cant help much beyond telling my experience, im using ubuntu 22.04.
Since you are willing to try different commits, I might suggest you try git bisect to actually figure which commit broke it.
I am looking into a different issue that I am seeing now that I have turn on FCM.
