Instruction/recomendations for upgrade from 21.04 to 22.04.1 Ubuntu?
- streety111
Is it possible to upgrade Ubuntu from 21.04 to 22.04.1 without consequences or is there something to consider?
- Снимок экрана 2022-09-27 105159.png (2.54 KiB) Viewed 1451 times
I really want to learn ZoneMinder
Re: Instruction/recomendations for upgrade from 21.04 to 22.04.1 Ubuntu?
You are probably on 20.04, not 21.04 which doesn't exist.
There were problems with ZM breaking when people did this. Check the forum here.
I'm staying on 20.04 as it's LTS and still supported.
- streety111
And at the same time, he writes that it is no longer supported, nothing can be updated, as well as downloaded from standard repositories.
- Снимок экрана 2022-09-27 130128.png (8.3 KiB) Viewed 1445 times
I see what you mean now. You're not on the LTS version and yes, you'll be unsupported. Sorry, I misunderstood.
Looks like you have to get to 22.04.
There might be some pain, but it's a good chance to learn.
- streety111
Thanks for the feedback.
Be sure you have a DB backup before you start. Worst case you load a new OS and ZM then restore. If the events remain untouched it should find them and you start where you left off.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
