I'm having difficulty getting the main/clear stream for the RLC-822A to work on ZoneMinder. The sub/fluent stream works fine.
Zoneminder version: 1.36.5
Camera firmware version: v3.0.0.412_21063007
OS: Ubuntu 20.04.2
For the main stream (which fails), I'm using the following path:
rtmp://10.10.30.100/bcs/channel0_main.bcs?channel=0&stream=0&user=admin&password=<my password >
I see the following errors in the log, and do not see any main stream video on the montage screens:
ERR Failed to prime capture of initial monitor zmc.cpp 258
ERR Unable to open input rtmp://10.10.30.100/bcs/channel0_main.bcs?channel=0&stream=0&user=admin&password=<my password> due to: End of file
For the sub stream (which works), I'm using the path:
rtmp://10.10.30.100/bcs/channel0_sub.bcs?channel=0&stream=0&user=admin&password=<my password>
Thanks in advance.
peryourhealth
RLC-822A on ZoneMinder reporting error "End Of File" on main stream.
Re: RLC-822A on ZoneMinder reporting error "End Of File" on main stream.
Have you tried rtsp with ffmpeg?
Extra points for the dodgy link.
