Orange Pi4 4GB version.
DISTRIB_DESCRIPTION="Ubuntu 18.04.5 LTS"
Linux soc-op4-01 4.4.179-g7b2dd521-dirty #5 SMP aarch64 aarch64 aarch64 GNU/Linux
Cameras: IP x 3
- Source: FFMPEG;
- rtsp://192.168.<cam_ip>/user=<my_user_name>&password=<password_here>&channel=1&stream=0.sdp (5 fps)
- Colorspace: 24bit
- Capture resolution: 720p
Running 1.37.0~20210604170235-bionic and getting several unwanted effects:
- Console shows that cameras work time to time. Say it can be that 3-d camera is red, it can be 1, 2 red 3-d is green, etc. Tested cameras with VLC and direct stream. All work fine. Solved
- Pretty much same situation with "montage" view. It shows "unable to stream" all cam, then one appears, then another does. No pattern. Solved
- On dark theme in Firefox [?] help text has white color and gray background, which is quite hard to read.
- Mocord records events in 2 second chunks instead of 10 minutes.
